Skarr05 Posted August 25, 2019 Report Share Posted August 25, 2019 I'm doing sr20det swap on datsun 510 coupe. What would be a good size fuel lines to replace the stock hard lines from the tank to the engine. Can I get help from somebody that has done this it's my first time doing this swap. Quote Link to comment
datzenmike Posted August 25, 2019 Report Share Posted August 25, 2019 The L series L16 fuel pump is capable of delivering 1,000cc or about a US quart per min. Naturally very little of this is used or even needed but this is the amount it can deliver. A quart is a lot of gas and I don't know any engine that can use that. The point is that the lines are good for that volume.... a quart per minute. I know the SR uses a higher pressure but volume wise how much is needed for 200hp anyway? It might be prudent to replace them because they were never intended for 50 PSI and they are about 50 years old. I would get pressure rated pipe no less than the current diameter. Like exhaust pipe size, people can get carried away and obsess over size. If stock is say... 3/16" then 1/4" should be lots. Find out what size Nissan put on SR powered vehicles, I bet they are surprisingly small diameter. Keep in mind that a doubling in diameter increases the flow by 4 times. A small increase from 3/16" to 1/4" increases the cross section by 77% Quote Link to comment
5t341tH Posted August 25, 2019 Report Share Posted August 25, 2019 I replaced all the hardlines on my sr20det swap with -6AN fuel lines. I used a retrofit in tank fuel pump from Fitech Quote Link to comment
Skarr05 Posted August 25, 2019 Author Report Share Posted August 25, 2019 Oh okay sounds good and u didnt have any problem with it. Quote Link to comment
5t341tH Posted August 25, 2019 Report Share Posted August 25, 2019 no issues of course. it should be plenty of of fuel coming in. Quote Link to comment
Skarr05 Posted August 25, 2019 Author Report Share Posted August 25, 2019 Do u use the stock fuel regulator or upgrade to aftermarket. I have the s14 sr20det motor Quote Link to comment
Skarr05 Posted August 25, 2019 Author Report Share Posted August 25, 2019 Do u know anywhere in l.a area where to buy intercooler coupling instead online. Quote Link to comment
