TheROCKMAN1 Posted August 25, 2019 Report Share Posted August 25, 2019 I have a 1978 Datsun 620 that needs the alignment to be adjusted. The truck veers to the right. I have looked up videos on how to adjust it, but can't seem to find one that helps solve my problem. I am not sure how to adjust the single bar tie rod that is on the truck. Any replies are greatly appreciated!😁 Quote Link to comment
datzenmike Posted August 25, 2019 Report Share Posted August 25, 2019 It's called the 'cross rod' and links both L&R tie rods. Loosen the lock nuts on both sides and turn the cross rod. One way toes out..... the other toes in 1 Quote Link to comment
Ben_upde Posted August 25, 2019 Report Share Posted August 25, 2019 12 hours ago, datzenmike said: It's called the 'cross rod' and links both L&R tie rods. Loosen the lock nuts on both sides and turn the cross rod. One way toes out..... the other toes in It adjusts both at the same time so you will need to split the difference of what you feel the 1 side to be off. Quote Link to comment
distributorguy Posted August 25, 2019 Report Share Posted August 25, 2019 If you're trying to fix an off-center steering wheel, that's different from fixing a truck that pulls to one side. Pulling is more likely caster or camber problem caused by bent or worn suspension parts: bushings, ball joints, tie rod ends; or a bad tire - smaller, edge worn, tapered tread, etc... Swap tires left to right and see if it helps? Quote Link to comment
datzenmike Posted August 25, 2019 Report Share Posted August 25, 2019 Roads are crowned to the center so only makes sense a vehicle will wander to the right. However a toe out makes this even more pronounced. Was, or is, this truck lowered??? Lowering onside a narrow range of normal ride height will definitely change the toe and at extreme limits will cause camber changes. Before bothering with an alignment first get the vehicle to proper ride height. 1 Quote Link to comment
