TimmyG Posted August 24, 2019 Report Share Posted August 24, 2019 @datzenmike I did this and my output shaft rotated 9.5 times.... did I manage to f*** this up??? 😂 1 Quote Link to comment
datzenmike Posted August 25, 2019 Report Share Posted August 25, 2019 It would seem so.  9 turns would mean you are likely in 2nd gear.  1...3...5 2...4...R   If the shifter is off the transmission, the striking rod should be pulled back towards the rear to get into first gear. 1 Quote Link to comment
TimmyG Posted August 25, 2019 Author Report Share Posted August 25, 2019 31 minutes ago, datzenmike said: It would seem so.  9 turns would mean you are likely in 2nd gear.  1...3...5 2...4...R   If the shifter is off the transmission, the striking rod should be pulled back towards the rear to get into first gear. Yeah, I have no idea what gear it was left in. I figured that did matter, however I've yet to actually ever take apart a transmission. Give it time, tho.  In the meantime I will redo this test correctly! 1 Quote Link to comment
