TimmyG Posted August 21, 2019 Report Share Posted August 21, 2019 Is this a factory oil pan for 4wd 720? I'm not familiar with them. 1 Quote Link to comment
Charlie69 Posted August 21, 2019 Report Share Posted August 21, 2019 Yes because of the front diff. Quote Link to comment
TimmyG Posted August 21, 2019 Author Report Share Posted August 21, 2019 Just now, Charlie69 said: Yes because of the front diff. Thanks. That makes sense. I bought the truck with the engine sitting in the bed, so never seen it in the engine bay yet. 1 Quote Link to comment
datzenmike Posted August 21, 2019 Report Share Posted August 21, 2019 9 hours ago, TimmyG said: Is this a factory oil pan for 4wd 720? I'm not familiar with them. Depends. The Z series were bulged on the right and the 1980 with the L20B were bulged on the opposite side... 1 Quote Link to comment
TimmyG Posted August 21, 2019 Author Report Share Posted August 21, 2019 Should have said it's an 84 with z24 1 Quote Link to comment
Charlie69 Posted August 22, 2019 Report Share Posted August 22, 2019 (edited) It does not matter L or Z as the 2wd and the 4 wd pans for both series engines are different because of the front diff. Edited August 22, 2019 by Charlie69 1 Quote Link to comment
datzenmike Posted August 22, 2019 Report Share Posted August 22, 2019 If Z24 then it matters that you have the Z series oil pan if 4x4. The picture I posted is for the '80 4x4 which had an L series engine. This looks like the right side of a Z series engine, bulge on the right. This is the front on an L series 4x4 oil pan, bulge on the left. 2wd pans are all more or less the same for all Z series. The L series is similar but leans about 18 degrees to the right side at the top. See above picture. Quote Link to comment
