72 510 Park/Tail fuse terminal getting hot
CS310
Hey guys, I need some help with my 72 510. The park/tail fuse terminal gets hot when I turn on the parking lights. Only the outside terminal. This is what I’ve tried so far.
Replaced the fuse
Cleaned the fuse box terminals
Swapped out the fuse box
Swapped out the light switch
Unplugged all the rear lights (This seemed to help. The terminal stayed somewhat cool. Maybe a fuzz hotter.)
The wiring on this car was a mess when I bought it. I’ve been slowly cleaning it up.
Any suggestions would be appreciated.
  • Replies 6
Heat is caused by resistance to current flow. Replacing everything else can only increase the current flow and make it hotter. This is why it was cooler after disconnecting some of the lamps. You have some resistance where the fuse contacts the clips that hold it. Heat will also take the temper or springiness out of the clips, the clips don't grip the fuse as well and the contact is worse and it makes more heat. A vicious circle. If the clips are not heat damaged and have good grip try the following.
I imagine the clips are brass or some copper alloy. My 620 box was tarnished and looked like an old brown penny. I removed it, washed in soapy water to remove any oil residue and filled a suitable size container with Real Lemon, lemon juice and about 1/4 cup of table salt dunked it in and brushed it with an old tooth brush then soaked it over night. Rinse with tap water and shake dry.
If the clip is damaged try wiring in an inline fuse just for the tail lights. Be sure the fuse is the correct amperage and the wire as heavy a gauge as possible. New ones use the more common bayonet fuses.
61qUHiIUnIL._SX425_PIbundle-5,TopRight,0
I wanted to give an update on my issue. This is what I did.
1. Checked all the grounds for the lights. No problem here.
2. Cleaned the white wire connector coming out of the fuse box. This looked good before cleaning but wanted to be sure.
3. Cleaned and soaked the fuse box in lemon juice and salt. This worked amazing. Also used a brush with a dremel on low speed to do a final cleaning.
The result was good. The park/tail fuse was much cooler. Still a fuzz warm. No where near what it was.
Then I discovered a mistake on my part. When I replaced the park/brake bulb receptacles, I switched the park and brake wires. So when I would turn on the parking lights, the brighter 1/2 of the bulb would light up, using more power.  I switched this and the fuse box is nice and cool..
i appreciate all the suggestions and advice.
