Ben_upde Posted August 14, 2019 Report Share Posted August 14, 2019 Since the photos I posted on the FB resulted in tons of questions asking for further explanation how I made the parking brake work with Trooper rear calipers and stock 620 cables, I made a quick ‘how-to-ish’ video. Lucas Films beware.... 3 Quote Link to comment
FrankRizzo Posted August 15, 2019 Report Share Posted August 15, 2019 Nice work. FWIW, I bought the rear Isuzu cables from rock auto and cut the ends off the non-caliper side, then cut the ends off the 620 cable after the splitter and joined them together with 3/16 stainless cable clamps. I had to bend the factory caliper clamp about 15 degrees to avoid wheel/suspension contact and used 3/8 one hole cable brackets to hold the cable to the frame near the tire. 1 1 Quote Link to comment
Ben_upde Posted August 15, 2019 Author Report Share Posted August 15, 2019 9 hours ago, FrankRizzo said: Nice work. FWIW, I bought the rear Isuzu cables from rock auto and cut the ends off the non-caliper side, then cut the ends off the 620 cable after the splitter and joined them together with 3/16 stainless cable clamps. I had to bend the factory caliper clamp about 15 degrees to avoid wheel/suspension contact and used 3/8 one hole cable brackets to hold the cable to the frame near the tire. I am sometimes a bit cheap for my own good so I went the route that cost exactly $0 😂 1 Quote Link to comment
