datzenmike Posted August 18, 2019 Report Share Posted August 18, 2019 There were 210 stock L16 heads, A87 L18 heads and U67 and W58 heads (sometimes the odd A87) on the L20B. Anything else showed up in the mix from used import engines in the '70 and '80s. Quote Link to comment
thisismatt Posted August 18, 2019 Report Share Posted August 18, 2019 #1 continuing to run L series 😁 2 Quote Link to comment
iceman510 Posted August 22, 2019 Report Share Posted August 22, 2019 On 8/17/2019 at 4:22 PM, Tom1200 said: A friend allegedly has a line on a twin carb L16 (SSS?) that can be had stupid cheap..........if it pans out I'll likely stop being lazy and do the swap. Otherwise I'll eventually get off my duff and build a 1600cc A-series motor. In the meantime I've been redoing the engine cowl/tail section on my 87 Novakar Formula 500..........so I'm not completely lazy. Tom, if you want some L16 engines, I have various blocks, cranks, etc. Even a couple heads I could part with. Some might even be performance builds already. Most came from ITC 510 cars. I got a pile of these with a car I bought last year, and I plan to use only one of them. I am in Michigan, so not close-but perhaps deals could be worked. Is there a private message option on Ratsun? I don't see it right off and I have never used it. If there is, you can send me something there if interested. Otherwise reply here if you want. Quote Link to comment
wayno Posted August 22, 2019 Report Share Posted August 22, 2019 On 8/17/2019 at 1:57 PM, datzenmike said: That would be the 219 head and flattops* for 9.29 compression and just a hair under 100HP. This was the late 60s early 70s when engine power was posted in gross HP. I think about 85HP would be more meaningful. * has to have flattops for the closed chamber head to work and raise the compression. A closed chamber head on a stock L16 produces an 8.21 compression. An open chamber head is well down into the 7.7 range. You have been all over the place with compression numbers for a while now, you told me that with a Z20s block with flat top pistons and my closed chamber W53 head I was at 10.8, above you say 9.29, this confuses me. Quote Link to comment
G-Duax Posted August 22, 2019 Report Share Posted August 22, 2019 Maybe depends on how much Labatt Blue he has had..... 1 Quote Link to comment
datzenmike Posted August 23, 2019 Report Share Posted August 23, 2019 On 8/17/2019 at 1:57 PM, datzenmike said: That would be the 219 head and flattops* for 9.29 compression and just a hair under 100HP. This was the late 60s early 70s when engine power was posted in gross HP. I think about 85HP would be more meaningful. * has to have flattops for the closed chamber head to work and raise the compression. A closed chamber head on a stock L16 produces an 8.21 compression. An open chamber head is well down into the 7.7 range. 6 hours ago, wayno said: You have been all over the place with compression numbers for a while now, you told me that with a Z20s block with flat top pistons and my closed chamber W53 head I was at 10.8, above you say 9.29, this confuses me. The 9.29 compression was for the L16SSS mentioned by Tom1200 in the post above mine. An L20B or Z20 (with 25% more displacement) flattops and a closed chamber head would be close to 10.7 Quote Link to comment
datzenmike Posted August 23, 2019 Report Share Posted August 23, 2019 4 hours ago, G-Duax said: Maybe depends on how much Labatt Blue he has had..... Wish I could use that excuse but too much Molsen's middle. Quote Link to comment
