Spaceman Posted August 6, 2019 Report Share Posted August 6, 2019 This is my new baby I'm going to pick her up this Friday I'm so excited.. Do all 79 have disk brakes and a 5 speed Quote Link to comment
Ben_upde Posted August 6, 2019 Report Share Posted August 6, 2019 Disc brakes yes, 5 speed no. I don’t believe that one has it as they typically put a decal on the back just like the King Cab decal. Not saying it can’t have a 5 speed though. Quote Link to comment
sebpv Posted August 6, 2019 Report Share Posted August 6, 2019 Theres a spot on the left side of the tailgate that is square. Could it be that said sticker that wore out? Quote Link to comment
Spaceman Posted August 6, 2019 Author Report Share Posted August 6, 2019 I'm not sure if that's a sticker for the 5 speed or not but I will know more when I go pick it up.. They lady I'm buying it from is in California and the truck is in Oklahoma so she really doesn't know much about the truck 1 Quote Link to comment
Spaceman Posted August 6, 2019 Author Report Share Posted August 6, 2019 They lost the key for the locks and ignition so I'm gonna need to replace the ignition switch when I get there is that hard to do and do u know what tools I will need to have to do the job 1 Quote Link to comment
Charlie69 Posted August 6, 2019 Report Share Posted August 6, 2019 A paper clip to release the lock cylinder if you are replacing the cylinder only. Quote Link to comment
Crashtd420 Posted August 6, 2019 Report Share Posted August 6, 2019 4 minutes ago, Charlie69 said: A paper clip to release the lock cylinder if you are replacing the cylinder only. If the cylinder is removed that easily could it be taken to a lock Smith to have a new key made? Quote Link to comment
Spaceman Posted August 6, 2019 Author Report Share Posted August 6, 2019 Ok thanks.. I'm gonna use a new switch and key I purchased for my 73 Quote Link to comment
datzenmike Posted August 7, 2019 Report Share Posted August 7, 2019 11 hours ago, Charlie69 said: A paper clip to release the lock cylinder if you are replacing the cylinder only. 10 hours ago, Crashtd420 said: If the cylinder is removed that easily could it be taken to a lock Smith to have a new key made? I could be wrong but I think you need to have the key in the ignition before you can release the cylinder with a paper clip. 1 Quote Link to comment
Charlie69 Posted August 7, 2019 Report Share Posted August 7, 2019 You are correct Mike. The key has to be in and turned to I think it is accessories to be able to remove the cylinder with the paper clip. Take that switch assembly out and order a complete switch from Rock Auto. You want the complete switch for $25.79. https://www.rockauto.com/en/catalog/nissan,1979,620+pickup,2.0l+l4,1210150,electrical-switch+&+relay,ignition+starter+switch,4700 79 620 complete ignition switch Quote Link to comment
