TimmyG Posted August 6, 2019 Report Share Posted August 6, 2019 Wondering if the bed on this 82 Datsun 720 is too far gone to be saved. I know it's hard to say for sure just from pics, but I could use some opinions. I don't have experience with rust removal. Thx Quote Link to comment
datzenmike Posted August 6, 2019 Report Share Posted August 6, 2019 That's nothing but this is a problem with the 80-84 trucks that had the seam where the bed floor meets the two outside panels. The '85 switched to a one piece side panel. Quote Link to comment
TimmyG Posted August 6, 2019 Author Report Share Posted August 6, 2019 31 minutes ago, datzenmike said: That's nothing but this is a problem with the 80-84 trucks that had the seam where the bed floor meets the two outside panels. The '85 switched to a one piece side panel. Yeah I'm familiar. Just don't know if this old bed is too much work. I don't know how to go about removing rust inside the seams. Possible? Quote Link to comment
datzenmike Posted August 6, 2019 Report Share Posted August 6, 2019 Not really, the seam is spot welded. it would need to be sealed on all sides Quote Link to comment
]2eDeYe Posted August 6, 2019 Report Share Posted August 6, 2019 That is light rusting compared to some I've seen lol. Wire wheel, rust converter soaked into the seam, proper sealing primer and paint should fix that right up. You will need clean the metal about 1-2" into the paint to make sure you get all of the rust. 3 Quote Link to comment
datzenmike Posted August 7, 2019 Report Share Posted August 7, 2019 ... and do the inside. 2 Quote Link to comment
slim_jimmy7 Posted August 7, 2019 Report Share Posted August 7, 2019 Laughs in Northern Iowa... I've seen worse rust on 2016 Fords 1 Quote Link to comment
tr8er Posted August 7, 2019 Report Share Posted August 7, 2019 29 minutes ago, slim_jimmy7 said: Laughs in Northern Iowa... I've seen worse rust on 2016 Fords You see a 2016 still running? Quote Link to comment
