Repairing the Fuel Pump Control Unit (Relay)
spddm0n
Posted (edited)
I thought I should probably start a new thread on this topic, rather than piggyback off another related thread.
I'd like to repair the fuel pump replay (fuel pump control unit).  I know there is a magazine article that talks about soldering a couple of the leads, where the solder begins to crack over time.  I had a different failure.  I burned out of the fuses on the board, and a second one looks like it's been overheated too.  Has anyone ever taken there's apart to make this repair and have any pictures of it?  Or, have one laying around that could tell me what the correct color bands (size) of the resistors on the board are?
I would like to replace a couple resistors to repair mine, but since its burned up, I cannot determine the color bands on the body of the fuses. 🙂
Here is what mine looks like.
Edited by spddm0n
  • Replies 14
None of that info is in a service manual, it's just replaced. I don't know what you could do other than to just wire it on with the ignition. I had one apart and it's slightly different that that one.
Posted (edited)
Yeah, I understand.  I figure that some others may have removed their's in attempt to repair it, like in the magazine article, didn't have success getting it to work, and kept it (still haev it lying around or have pics).  I would imagine they would be the same if the part number was the same. 🙂  I'm just hoping for a clear understanding of the size of the resistors.  They should be easy to replace. 🙂
I'll upload a pic of the part number too.
Edited by spddm0n
You get the part number and I will check one of mine and see if it is the same.  If it is I will open mine up to get the resistor color code for you.
Posted (edited)
Excellent!  I just uploaded more pics to the original post #1).  Part number on mine is: 28545-89900.
If you remove yours and open it up, be careful with the little screws on the back, they can strip easily.  Once the cover is off, you lift out the black plastic base (shouldn't even need prying) and remove the circuit board.  In order to remove the circuit board from the main body, flip the unit over and work on pressing down on the 6 metal spades that protrude through the main plastic body.  They slide through nicely if you keep them moving down and through the body evenly.  The spade alignment with the body are what are keeping the circuit board held into the plastic body. 🙂
Thanks!!!
Edited by spddm0n
Nissan wanted $180 for a fuel pump relay and 6-8 weeks delivery time. I bought two (one as a spare) online for about $70. Why would you want to screw with a broken one?
$0.03 vs. cost of a new cheap Chinese version. 😉
spddm0n I have been busy I will try to look tomorrow.  All my trucks are 2 wheel drive but I think I still have an 85 4x4 harness that should have the fuel pump relay with it.
Thanks Charlie.  That would be great.  The fuel pump replays are the same for all Z24 applications produced 11/1982 and later.  I did find one (chinese-made) in the salvage yard truck the other day, and the truck is up and running again, but I would love to know the resistor sizes if you get around to checking.  Never know how long the new one will last.  The newer ones are all printed circuits (obviously), and who knows how well the components will last. 🙂
Never seen a Chinese one.  I have one that does not work but I have not taken the time to open it up to see what is wrong.  Is your fuel pump a factory unit or is it aftermarket?
What I mean by Chinese is all the current replacement parts for nearly any vehicle that you buy at Autozone, Pep Boys, Advanced Auto, etc. like the one in the photo above.  It's some American company, but producing it in China.
My fuel pump looks factory, but I haven't removed it to check.  It's still working. 🙂
With my cameras I could not get a good picture of it but on mine R1 Is the same color code as R4.
  • 6 years later...
Yep thats the one - Import direct - bought it through Oreilly's. Lasted 4 days with my OEM pump. Its junk. Opened it up and looked cheap. Learned my lesson.
Posted (edited)
I took my stock one apart and the copper wires were burnt up.Went to Auto Zone and spent 52 bucks and bought one and it still works after 6 years with a Nissan fuel pump.Not the original Nissan pump.Wonder what goes wrong when the Nissan pumps goes bad.And how to take it apart.Never had a problem with the little filter in it cause my gas tank is clean and so is my Weber's little fuel filter.Never heard anyone taking a Nissan fuel pump apart and fixing it but the FSM says something on this in my 85 FSM in the Canada section.Talk to me Mike.I have  the last Nissan pump in my shed and a brand new one in the Nissan box.Also Nissan sells no inside replacement parts.
Edited by Thomas Perkins
  • 7 months later...
FYI, that relay is imported by Carquest and sold by Advanced Auto: https://shop.advanceautoparts.com/p/carquest-premium-multi-purpose-relay-raa1927/12441399-P
Mine is acting strange (only switching on when voltage increases) so I'm ordering a SMP imported one.
