silroc Posted July 19, 2019 Report Share Posted July 19, 2019 Dug into it and found the big bolt holding the lower pulley was loose as was the pulley itself. Doesn't look good - the woodruff key was sheared over and worn down, the pully ID looks messed up and its' slot. The crankshaft key slot looks bad too. Otherwise the crankshaft has some marks on it, but looks like the pulley was the softer metal. So... how bad is the news? Do I look for a replacement pulley (stock or aftermarket?) Or get this one machined if that's possible. Does anyone have info for a replacement woodruff key (dimensions, availability)? While I'm at it, was considering new radiator with electric fans, in which case I'd want to remove the upper fan and "TEM-COUPLING" unit. Is there anyway to remove that TEM-COUPLING part or do I have to install a new water pump that doesn't have one? Thanks much 1 Quote Link to comment
datzenmike Posted July 19, 2019 Report Share Posted July 19, 2019 Definitely the pulley must be replaced. Unfortunately the crank slot is damaged enough that it may not support the woodruf key and this will happen again. Was the crank bolt loose? This may have been the cause. Someone may have had this apart and failed to get it torqued properly. Well nothing to loose here. Put together and make sure the bolt is torqued to 120ft.lbs. That alone should hold it. Only way to remove the clutch on the water pump is to cut it off. Do NOT cut too close to the press on pulley. Slice the aluminum parts with a cut off disc. You'll do best if you break off smaller parts. It's difficult to do without slicing the pulley. Avoid doing that. Expose the bearing... Here you can stop or carefully slit the steel races and keep going. Stay at least 1/8" away from the pulley directly behind it. It's pressed onto the same shaft 1 Quote Link to comment
silroc Posted July 19, 2019 Author Report Share Posted July 19, 2019 Yeah the bolt was loose. Do you know if the pulley and keys are available anywhere? I poked around on the internet some without luck so far. woodruff key = Nissan #00926-51600 Pulley = Nissan #12304-B9800 or 12303-U6000 Btw, I'm now retired so have started on my 620 project. I wanted to get this problem fixed first so I can run the engine some. I'll be posting progress pic's as I go. Not sure how much people want to see. Seems with this website everyone has been there, done that. Thanks for the help as always. 1 Quote Link to comment
Crashtd420 Posted July 19, 2019 Report Share Posted July 19, 2019 There are 2 pulleys on ebay... I think they are the right ones.... https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F153484155623 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F401816280649 1 Quote Link to comment
Crashtd420 Posted July 19, 2019 Report Share Posted July 19, 2019 Here's the key.... https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F163700286105 1 Quote Link to comment
silroc Posted July 19, 2019 Author Report Share Posted July 19, 2019 Excellent! Thank you, Crash 1 Quote Link to comment
Stoffregen Motorsports Posted July 19, 2019 Report Share Posted July 19, 2019 The crank damage looks bad, but what have you got to loose? Try installing the new key and pulley, and use red loctite on the crank pulley bolt before you torque it down. The damage is already done. It is possible to have that repaired, but it may not be worth it. 1 Quote Link to comment
Ben_upde Posted July 19, 2019 Report Share Posted July 19, 2019 (edited) 54 minutes ago, Stoffregen Motorsports said: The crank damage looks bad, but what have you got to loose? Try installing the new key and pulley, and use red loctite on the crank pulley bolt before you torque it down. The damage is already done. It is possible to have that repaired, but it may not be worth it. I’d err on the safe side and use green loctite. It is designed as an adhesive/retainer. I’ve used it to hold spun bearing races in skid steers and similar applications with great success. Apply it to the key, the keyway and all around the crank snout. Assemble and torque then leave it to cure for a day or so. Only caveat, she isn’t coming apart again without some serious heat applied liberally. Edited July 19, 2019 by Ben_upde 2 Quote Link to comment
Stoffregen Motorsports Posted July 19, 2019 Report Share Posted July 19, 2019 I thought of that too. It wouldn't be a bad idea to use both: the green on the snout, and red on the bolt. 1 Quote Link to comment
datzenmike Posted July 20, 2019 Report Share Posted July 20, 2019 As long as you can remove it at a later date. Torque to 90-116 ft lbs. It ain't coming off. 1 Quote Link to comment
Charlie69 Posted July 20, 2019 Report Share Posted July 20, 2019 Buy 2 of the woodruff keys and pulleys so if it fails again you will have them when you rebuild your engine and replace the crank. 1 Quote Link to comment
Stoffregen Motorsports Posted July 20, 2019 Report Share Posted July 20, 2019 It sounds like rebuilding the engine is not something he's interested in. 1 Quote Link to comment
Charlie69 Posted July 21, 2019 Report Share Posted July 21, 2019 Might not have a choice if he wants to drive it. Quote Link to comment
silroc Posted October 27, 2019 Author Report Share Posted October 27, 2019 I put the new pulley on - without a key but with the recommended locktite and torque - holding so far so good. Before I put it all back together I cleaned up the engine compartment. I applied an Everbrite satin to give it a little shine. I only ran it for about 15 minutes to warm it up for a compression check. That turned out good with about 163-165 psi on all four cylinders. However, a couple things from that little run time; First, it sucked down a gallon of gas sitting there idling for 10 minutes! Is that do be expected? Seems like the exhaust fumes are heavy - not white, blue, or black, just noxious! Secondly, I pulled out the brand new set of plugs to take a look and found #1, #2 coated dry black. Again, this after only 15 minutes of run time. Maybe some connection with the poor gas mileage and these two cylinders? What would cause only two cylinders to be this way? Quote Link to comment
datzenmike Posted October 27, 2019 Report Share Posted October 27, 2019 I imagine a gallon is just an exaggeration. #3 and #4 are lean and #1 and #2 are rich. Did it even run???? Did the engine shake while idling??? Can you take the air filter off and post a picture of the intake where the brake booster hose joins it??? Firing order looks right. Looks like the heater hose from the back of the head is looped and connected to the return at the lower rad hose??? This is only a good idea if you can somehow plug it so there is no flow through it. The heater has a shut off valve when not being used. This is a lot of hot water that is being sent right back into the engine with out being cooled by the rad or the heater. Quote Link to comment
banzai510(hainz) Posted October 27, 2019 Report Share Posted October 27, 2019 (edited) At idle it should run a minute or 2 w/o any gas going to it after one pulls the fuel line float level not right ck the valve lash but since you had good comp numbers most likely it’s good make sure intake ,carb tight Edited October 27, 2019 by banzai510(hainz) Quote Link to comment
silroc Posted October 27, 2019 Author Report Share Posted October 27, 2019 You guys are quick on the help! I ran the fuel line into a little 1 gallon gas can (I don't know what's in the tank), and it definitely used that up. This is my first L20, but have listened to quite a few motors in my time. To me it sounds like it runs OK. What I would expect for an old truck 4-banger. I guess a little shake initially, but smoothed out after a minute. Rev'd it up towards the end, seemed fine. Nothing slips by you Mike - I did that with the heater hose just temporarily. Good tip tho - guess I could just clamp the hose to stop the flow next time. Here are a couple of pics as you asked for Quote Link to comment
datzenmike Posted October 27, 2019 Report Share Posted October 27, 2019 I was hoping to find the brake booster hose loose and leaking air into the 3 and 4 runner. This would make the mixture lean. Can you inspect for looseness or cracks in those hoses. Check the top intake mounting bolts are snug. 3 and 4 should look more like 1 and 2. Just to satisfy my curiosity, could you pull plug #3 and #4 wire off separately, put and old plug in the end and lay on a grounded surface. Crank the engine with the starter and see if there is a spark? Quote Link to comment
banzai510(hainz) Posted October 28, 2019 Report Share Posted October 28, 2019 since the crank pully woodruff key is not lined up as stock I assume your going to have to find TDC and mark where Zero is so you can time it soemwhat Quote Link to comment
silroc Posted October 29, 2019 Author Report Share Posted October 29, 2019 I did a little experiment with all the plugs hooked up at the same time so I could compare the sparks. Here is the video of the cranking (in the dark). https://imgur.com/V8TrdTb https://i.imgur.com/V8TrdTb.mp4 Newbie to Imagur too, don't know why the video link doesn't work like the pic's. Kind of hard to tell if all the sparks are equal. They all seem to spark brighter/dimmer sometimes. But at least they are all firing. Haven't checked the manifold bolts yet. When installing the new pulley, I eye-balled the crank slot and made a mark so I could line up the pulley slot with it. I think its pretty close - I'd say within a 1/32. I figured these engines aren't all that precise! Quote Link to comment
Stoffregen Motorsports Posted October 29, 2019 Report Share Posted October 29, 2019 I would strongly recommend against running the engine without a crank key. I understand your situation, but it's a failure waiting to happen. Quote Link to comment
silroc Posted October 30, 2019 Author Report Share Posted October 30, 2019 Thanks for the advice. Coming from someone with your experience, I take it to heart. 1 Quote Link to comment
Stoffregen Motorsports Posted October 30, 2019 Report Share Posted October 30, 2019 I've honestly never installed a crank pulley (non-damper) without a crank key, but I have seen what happens to them when the bolt comes loose. Pulleys get welded to crank snouts, or get wallowed out by being loose. I've even seen crank snouts snap off. If you used a sleeve retainer where the pulley slides onto the crank, it may allow it to stay put long term, but therein lies the problem...you'll never get it off. Definitely keep us posted. I'd love to hear how this holds up. Quote Link to comment
bottomwatcher Posted October 31, 2019 Report Share Posted October 31, 2019 Really nice job on setting up a properly grounded set up for testing spark. Most everyone including myself jury rigs some kind of half assed hope it is grounded kind of setup that may show the spark or has some kind of defect in the circuit. I feel a little smarter after witnessing this. Thanks! Quote Link to comment
CHL2T Posted November 3, 2019 Report Share Posted November 3, 2019 I had the same crank pulley situation with a 91 prelude. Crank key gone. damage to the crank, damage to the damper/ pulley, no damper/ pulley to be had anywhere after hours of searching online so I just decided to just put it back together. I wish I'd seen this tread before you (OP) had put yours back together without a woodruff. I would have told you to go to your local ACE hardware bolt bin and get a new key to install. Mine local one had actal woodruff keys but the prelude needed a square one so I picked one up cut it in half, installed pulley and bolt with blue locktite. In hindsight, I should have used the locktite on the key as well. Put it back together and fired it up and it seems to be holding 1 Quote Link to comment
