89Sunny 2 Report post Posted July 7, 2019 It's me again. So I got the T3 Coilovers installed and they look fantastic. BUT when I got low enough to level out front to back I get an odd "clunk" It sounds like the spring is hitting the side of the shock tower but it's not. Any idea? Clues? Thoughts? Quote Share this post Link to post
Duncan 2,586 Report post Posted July 11, 2019 Can't really diagnose it unless in person. You might enlist some help from a friend, and have them rock it while you climb under to see if you can pinpoint it. With that big of a clunking noise, I wouldn't think that would be terribly difficult to find. Quote Share this post Link to post
datzenmike 37,383 Report post Posted July 11, 2019 Strut is probably bottoming out. Quote Share this post Link to post
89Sunny 2 Report post Posted July 11, 2019 7 hours ago, Duncan said: Can't really diagnose it unless in person. You might enlist some help from a friend, and have them rock it while you climb under to see if you can pinpoint it. With that big of a clunking noise, I wouldn't think that would be terribly difficult to find. You would think it would be easy to diagnose but it's not. I have had people rock it, I can rock it etc but it's hard to find where exactly the noise is coming from. Quote Share this post Link to post
89Sunny 2 Report post Posted July 11, 2019 7 hours ago, datzenmike said: Strut is probably bottoming out. I am going to agree with this one. If I leave about an 1" on the threads and do not take it down to 1/2" left on the threads it seems to be ok. The odd thing is/was that the drivers side would not get the same "clunk" when set to the same height. I am currently running with it at the 1" mark but it has my truck sitting 1/2" higher in the front. Quote Share this post Link to post
datzenmike 37,383 Report post Posted July 11, 2019 Variables. The spring may be even slightly stiffer/softer on one side or it's slightly heavier on one side. If intending to go that low, really all you can do is increase the spring constant but it may be too stiff for your liking. Quote Share this post Link to post
thisismatt 8,130 Report post Posted July 11, 2019 Drop the spring perch all the way and find where it's bottoming out. Get shorter inserts and shorten tubes if necessary. Quote Share this post Link to post
89Sunny 2 Report post Posted July 11, 2019 10 hours ago, thisismatt said: Drop the spring perch all the way and find where it's bottoming out. Get shorter inserts and shorten tubes if necessary. I though of this too BUT I just spent quite a bit having these made I am in no hurry to pay to make new ones. I'll ride 1/2" higher in the front for now. Quote Share this post Link to post
89Sunny 2 Report post Posted July 11, 2019 11 hours ago, datzenmike said: Variables. The spring may be even slightly stiffer/softer on one side or it's slightly heavier on one side. If intending to go that low, really all you can do is increase the spring constant but it may be too stiff for your liking. It;s pretty stiff already at it's current height. I have the Konis at mid stiffness. I'm leaving it for now I just wondered if any of you all had run into such a noise. Quote Share this post Link to post
thisismatt 8,130 Report post Posted July 11, 2019 2 minutes ago, 89Sunny said: I though of this too BUT I just spent quite a bit having these made I am in no hurry to pay to make new ones. I'll ride 1/2" higher in the front for now. So you have how much travel at this point? Quote Share this post Link to post
89Sunny 2 Report post Posted July 11, 2019 Side question Icehouse said he is running 510 LCAs and TB. What difference do they make? Anyone know? They look pretty similar to the ones I am currently running. There are adjustable sets out there. Quote Share this post Link to post
89Sunny 2 Report post Posted July 11, 2019 Just now, thisismatt said: So you have how much travel at this point? as it's sitting now not much at all. It's a very stiff ride and It will still bottom out over larger bumps at speed. Quote Share this post Link to post
graveltrapp 634 Report post Posted July 5, 2020 Like Matt said, Cut the tubes, Rabbit mk1 inserts, collars. and no more spring bind. Now you get to resolve the bump steer issues. Quote Share this post Link to post
graveltrapp 634 Report post Posted July 5, 2020 It looks really nice though, Quote Share this post Link to post
