Donki Posted July 1, 2019 Report Share Posted July 1, 2019 My 80 720 only has 110 thou miles it's the fuel window shows 3/4 full of gas but it's not spraying fuel it starts choke valve is closing all the way but it's not reving high runs for min then cuts out backfires out exhaust then dies it's stock Hitachi carburetor 1 Quote Link to comment
Charlie69 Posted July 2, 2019 Report Share Posted July 2, 2019 Rebuild the carb and be sure float level is correct. Check the fuel pump pressure also. Start a build thread in the 720 section. it is much easier for you to keep track of your posts (questions) if they are grouped together in a build thread. It also would make it easier for people to help you. 1 Quote Link to comment
