zewiz Posted July 1, 2019 Report Share Posted July 1, 2019 I'm running a 15 gal fuel cell, connected to a Carter fuel pump (with filters and all, etc) My question is, do you guys think I'll run into any issues with it mounted about the same level as the cell, and approx 24 in away? - pump further back into trunk than cell is (so cell closest to rear of car, pump towards front of vehicle) Quote Link to comment
Jesse C. Posted July 1, 2019 Report Share Posted July 1, 2019 I installed my pump to be at the lowest point i could get it to the fuel cell so the fuel will flow into it more naturally and the pump won't have to work too hard to draw fuel. Distance should not be a problem. Quote Link to comment
bottomwatcher Posted July 1, 2019 Report Share Posted July 1, 2019 No issues, but is this high pressure for fuel injection by chance? They are loud and there is a reason the mfgs mount them in the tank. Quote Link to comment
datzenmike Posted July 1, 2019 Report Share Posted July 1, 2019 Ideally as low as possible but lets not forget where the mechanical pumps sit way up front and high on an engine and they work just fine. Pumps can produce almost unlimited pressure on the outlet but are limited on the inlet by atmospheric pressure pushing the fuel in. This amounts to about 14.9 PSI or what ever 1 bar is. No pump, no matter how strong or efficient, can pull a liquid vertically more than about 30 feet. They can be loud or allowed to be louder if mounted in the tank but it's better protected in there and the fuel cools the pump. Quote Link to comment
Tom1200 Posted July 1, 2019 Report Share Posted July 1, 2019 Mine has about 18" worth of fuel line between the pump and the fuel cell, the pump is also mounted slightly above the top of the cell. Also note it's a cheap parts store pump, I have no issues whatsoever. Granted my motor isn't making 500hp either. Quote Link to comment
datzenmike Posted July 1, 2019 Report Share Posted July 1, 2019 You can always go to larger diameter inlet hose. I don't see a problem. Quote Link to comment
Stoffregen Motorsports Posted July 1, 2019 Report Share Posted July 1, 2019 The Carter pump is probably the best performing, and is less noisy than a Holley pump, but it is still very loud. They do come with rubber isolators to help quiet them down. Mounting them in the trunk is almost never a problem, and I've done it this way many times, but Bottomwatcher has a good point, if it's for EFI, you may want to re-think the placement. Here's one I installed a few years ago. Quote Link to comment
zewiz Posted July 2, 2019 Author Report Share Posted July 2, 2019 Thanks for all the input It is connecting to a Weber 32/36, so no EFI worries (or high HP) Sounds great, looks like I’ll stick with my plan then! Quote Link to comment
Crashtd420 Posted July 2, 2019 Report Share Posted July 2, 2019 16 minutes ago, zewiz said: Thanks for all the input It is connecting to a Weber 32/36, so no EFI worries (or high HP) Sounds great, looks like I’ll stick with my plan then! I know you said Carter but which model pump did you get...... Find a way to verify your preassure because the weber only wants around 3 psi.... Quote Link to comment
Stoffregen Motorsports Posted July 2, 2019 Report Share Posted July 2, 2019 A DGV doesn't need any special fuel pump. A stock one will supply all that you can burn. But if you insist on the electric pump, you will need a good pressure regulator too. I usually run a new hard line from the tank to the engine bay so I can put the regulator on the passenger side of the firewall. I use 3/8" line to accept -6 AN fittings, then plumb it to a low pressure Holley regulator. Like this - or this - For a single carb, you won't need a fuel distribution log, but it is a good place to put the psi gauge. 2 Quote Link to comment
zewiz Posted July 3, 2019 Author Report Share Posted July 3, 2019 12 hours ago, Crashtd420 said: I know you said Carter but which model pump did you get...... Find a way to verify your preassure because the weber only wants around 3 psi.... P4070 I believe.. and I’m running a regulator to keep psi in check 1 Quote Link to comment
hang_510 Posted November 28, 2019 Report Share Posted November 28, 2019 On 7/2/2019 at 9:48 AM, Stoffregen Motorsports said: good pressure regulator too. regulator on the passenger side of the firewall. I found with my Carter pump in the rear the DCOEs did fine w/o a regulater. pump mounted in the engine bay the regulator was necessary. 1 Quote Link to comment
