nissan720 Posted June 27, 2019 Report Share Posted June 27, 2019 will the transmission from a 1982 5 speed fit the 720.would the shifter location be the same? Quote Link to comment
datzenmike Posted June 27, 2019 Report Share Posted June 27, 2019 Will the '82 5 speed fit the '84 in your profile? Is this what you meant to say? It will if the following is true... Both the '82 or '84 are either gas or diesel engines Both the '82 and '84 are either 2wd or both 4wd. Both the '82 and the '84 transmissions are either 31.5" long or 26" long. Quote Link to comment
nissan720 Posted June 27, 2019 Author Report Share Posted June 27, 2019 well i meant to ask,will the transmission from a 1982 datsun 200sx fit a 1984 nissan 720.sorry for not wording the question correctly. Quote Link to comment
datzenmike Posted June 28, 2019 Report Share Posted June 28, 2019 7 hours ago, nissan720 said: well i meant to ask,will the transmission from a 1982 datsun 200sx fit a 1984 nissan 720.sorry for not wording the question correctly. Yes, it will fit into the truck.... if the '84 720 is a gas engine (Z20 or Z24) and transmission is 31.5" long. The S110 200sx may have more or less transmission switches for emissions than the 720 transmission. The '82-'83 S110 and the '84 720 5 speeds are exactly the same internal ratios too. Quote Link to comment
datzenmike Posted June 28, 2019 Report Share Posted June 28, 2019 Length is the big thing. The S110 will be 31.5" long. The 720 could be 26" or 31.5" Quote Link to comment
