CamoKing Posted June 19, 2019 Report Share Posted June 19, 2019 I couldn't just stop at cleaning, new gaskets, and a few other replacement parts from a kit. I had to tear the whole Hitachi DCR342 down to be thorough...including removal of the choke and lower butterfly plates. This was a learning experience. Wonderful! I've learned the term: STAKING After discovering that the screws were staked, I used a dremel to grind the ends and free them. (And, render them useless) Of course, that led me on a hunt for new screws which I found at Ace Hardware luckily. Each plate had a pair of different length screws leading me to an arduous mini milling task that, after several frustrating hours, and several rejects, yielded 3 pairs of new screws. I've reassembled these parts using some Permatex Red thread locker hoping that will suffice. The question arises then as to whether or not I need to 'stake' these little suckers and, if so, how does a 'back yard' novice mechanic with limited tools accomplish such a thing ? Quote Link to comment
datzenmike Posted June 19, 2019 Report Share Posted June 19, 2019 Best if they are soft brass and easily peened. I would use a permanent thread locker. Actually I wouldn't have removed them. 😄 The shaft would need to be supported so it doesn'r get bent while hammering on it. Hitachi probably uses a press. It's critical that the butterflies align and seal tightly when closed. Quote Link to comment
CamoKing Posted June 19, 2019 Author Report Share Posted June 19, 2019 Well, I think the Permatex Red is permanent? BUt, now I see the butterflies have are not closing tightly; small slivers of light coming through. Back to the bench ): Quote Link to comment
Stoffregen Motorsports Posted June 20, 2019 Report Share Posted June 20, 2019 Yes, you need to adjust the butterflies before fully tightening the screws. You can use red loctite on them, and you should also peen around the tips with a center punch. Quote Link to comment
