bilzbobaggins Posted June 11, 2019 Report Share Posted June 11, 2019 Local jy sent me an alert that they had a 80 710 on the yard. I assumed they meant 720 and yes, thats what it was. I did not have a tape on me to measure and I refuse to borrow/loan tools at the junkyard. I have some pics in my phone of the trans. Do the short tail and long tail trans mount up differently? Or could a keen eye figure it out from where the trans ends figure it out? If so, I will upload them. If not, not worth the time. Thanks Quote Link to comment
wayno Posted June 11, 2019 Report Share Posted June 11, 2019 The 1980 Datsun 720 has a long shaft, the short shaft didn't appear till maybe late 1984??? Short shafts and long shafts have the same transmission mount location, the short shaft ends about 4 inches past the transmission mount, the long shaft ends closer to 9" past the transmission mount. Quote Link to comment
bilzbobaggins Posted June 11, 2019 Author Report Share Posted June 11, 2019 (edited) Thank you. I was under impression that it could either be a long or short in 80. Still going to go back and measure. 39 years ago is lots of time for change. Edited June 11, 2019 by bilzbobaggins Quote Link to comment
bilzbobaggins Posted June 11, 2019 Author Report Share Posted June 11, 2019 Damn, these pics suck. Quote Link to comment
wayno Posted June 11, 2019 Report Share Posted June 11, 2019 The short shafts came in 2wd 1985/86 Nissan regular cab/short box trucks with a speedo drive in them, the later 4wd trucks(84?) also had them but they had no speedo drive, but one must look at all of the 4wd trucks as the transmissions are the same except for the speedo drive. Yes someone could have put a short shaft in a 1980 Datsun 720, but they would have had to change out the drive line also. Quote Link to comment
datzenmike Posted June 12, 2019 Report Share Posted June 12, 2019 This may also be a 4 speed. They were standard and the 5 speed an option up until October '83 when only 5 speeds were available form then on. Quote Link to comment
bilzbobaggins Posted June 12, 2019 Author Report Share Posted June 12, 2019 Do 4 speeds have a lockout on going straight from 5th to reverse? Cuz this one did. It felt like it clicked all the way into 5th as well. Quote Link to comment
