DAT410 Posted June 10, 2019 Report Share Posted June 10, 2019 Hi all Looking for some advice on replacement starter motor options, or at least starter solenoid replacement for my 410 (e1 motor, 3 speed manual)). The solenoid has gone and need to replace, but the replacement ones on ebay (based in US) don't seem to look like mine. Rather than searching for a solenoid, has anyone replaced the whole starter motor with something newer? Thanks Quote Link to comment
Draker Posted June 10, 2019 Report Share Posted June 10, 2019 It may be possible to take to a alternator/starter repair shop. That's usually my first plan if I can't find suitable replacements. Although, sometimes they just can't be fixed. Quote Link to comment
DAT410 Posted June 11, 2019 Author Report Share Posted June 11, 2019 Thanks Draker shop I went to weren’t any help at all. If I don’t get anywhere will have to try a proper specialist I guess. Cheers Quote Link to comment
datzenmike Posted June 11, 2019 Report Share Posted June 11, 2019 Wasn't the E engine similar to the J series? A lot of MG stuff will fit the J series also. Keep trying. Quote Link to comment
difrangia Posted June 11, 2019 Report Share Posted June 11, 2019 Is the solenoid mounted on the starter or on the fenderwell/firewall ?? Quote Link to comment
Crashtd420 Posted June 11, 2019 Report Share Posted June 11, 2019 7 hours ago, difrangia said: Is the solenoid mounted on the starter or on the fenderwell/firewall ?? To add to this are you trying to keep things original? You could do a remote solenoid and keep the starter.... Quote Link to comment
MikeRL411 Posted February 22, 2020 Report Share Posted February 22, 2020 He needs the solenoid that is mounted on top of the starter housing, not a remote starter relay ! In retrospect, he may just have a broken fork inside the main housing, not a problem with the coil per se. A broken fork will jam the starter so that it will not pull in. A fork from almost any NISSAN starter may fit. Quote Link to comment
difrangia Posted February 24, 2020 Report Share Posted February 24, 2020 I realize that this is an older thread and 'the water may be under the bridge', but this might help someone else needing to update the mid-late 1960's starter with integral solenoid for the pushrod engine. I've rebuilt a couple of these over past five years or so and parts are available out there if one is persistent. Some of these parts ( the solenoid and drive unit ) are common to some American starters. Here is a pic with some boxes including part numbers that might be cross-referenced. I picked up the two sets of British brushes out of Kuwait on US Ebay a couple years ago for pocket-change. Quote Link to comment
DAT410 Posted May 30, 2020 Author Report Share Posted May 30, 2020 Hi all Well after almost 12 months of having the starter work ok, it has now finally given up. Definitely is the solenoid that is the problem. At the moment it is at an auto electrician, but they are having trouble finding a solenoid that fits. I have searched online and whilst there is a few listed as fitting, the picture shown doesn't look like the one in mine... Even the one in above photo (thanks for posting difrangia) doesn't look similar. The end of the 'shaft' that pushes the starter cog on mine has rectangular slot in it. Does the one in the photo (and also ones on ebay) have this, and the nut end is just a cover? Once I get it back from the shop will post some pics. Thanks Quote Link to comment
banzai510(hainz) Posted May 30, 2020 Report Share Posted May 30, 2020 I would install a hot start relay just in case the key switch is weak. one way to Check is put a wire on the selinoid tap and hit the + side battery and see if the selinoid hits harder and throw the bendix out and gets the starter going I has this happen on my 521 and was swapping starters that would work for a week but O Riley’s said was good.I thought bullshit.but was a low voltage key switch. Try that test and if still bad then it’s the selinoid Quote Link to comment
difrangia Posted May 30, 2020 Report Share Posted May 30, 2020 The nut stays on the end of the solenoid shaft. The fork that pushes the starter drive gear into mesh with the flywheel gear mates to the solenoid shaft between the nut and the hat shaped washer. Take a look at this one: https://www.ebay.com/itm/Starter-Solenoid-ACE-Brand-Fits-Honda-600-S520/283535669980?fits=Make%3ADatsun&epid=76114239&_trkparms=ispr%3D1&hash=item42040afadc:g:0UAAAOSwtuFdEPZj&enc=AQAEAAACcIQvEcHUrT7nmUC3yY5qbPyaBN1nJEDYW8MyypsJPgXKVlA44ZLASBNW4fVOteB5X4CYymNR2kjfjlWuGXV5RpIFMAZXT0LCvbifJIRO333bLV93%2B64bSsVOCB36zMKT1J2MW2drcngP7vqkZE1VNBRt%2FhPa2%2FjghQEe%2F%2B5CXU5zfsyMH3xGicV5XPFB5nBCn0LP7U78YcCXiSy%2FPrApgsNBxAulwThCoVLfrVp8otrUdGVnlGXUlq5w1I4JmM1agIL5xNBsZj2XvyTxwnWLCNv9YsgsWrfmzhhlnqH8ZGn7APhftfYWVdIk7bBQ20pbaZPrwHMuO8u2Sl%2BRvFEoMgyH%2FKjtfc9nNZCT9FI4PViTAt84AqRFys73tQORdVxPsv4JYty1SecK2%2Bu6h93O%2BW9ATt1oh6UqiURJNJAcYsX0kJ6U2%2F4h91tqkgFtLsi0ssjsMkHempolo4MUIHh9AkvFR1QzsjuAjWOb1OVFVeqhwHx%2FW6JwS30%2BhGxxliIONQe0z5WTe4u39eq0YN7UbB%2FwPPRIFl0FD9d388HDygykHvtxfUJBaYCBz1gREUQI4X6KwBUtCu6dd4Ptdo92Hj9JK0zo3ypiS%2B1KcBYSLgDWLzXAoRViyJtqi3yvRpsUfOy7HobJM3NX1DJcUJFcTiMGiu8yRYzv6vvYDJ7wtVEVTydTtwHl1oqGkBsE6fK4jPwn9ZtoN7UyM0DaZBDjIXhXT88ENOHFG16FetA%2BXC4%2B%2B2n3aBBzHTGAQ2O3gwsku5ACXanqm%2F8%2FVVVhru6vueXeJRNzXuwjswBOp3seCIlDATHIhWstBpEDE%2FoPgCpNPw%3D%3D&checksum=2835356699805ec7971ff0674b7783310b9b9fe4debb Quote Link to comment
MikeRL411 Posted May 31, 2020 Report Share Posted May 31, 2020 In search of a hot starter relay? The automatic transmission version of the RL411 came with such a relay factory installed. If by chance you come across the stripped carcass of such a RL411 pull the relay and refer to an appropriate wiring diagram for correct installation. Should apply to the right hand drive R411 version also. Quote Link to comment
DAT410 Posted June 5, 2020 Author Report Share Posted June 5, 2020 Ok so I got the starter back and have attached some photos (hope the link works!). Can anyone help identifying it, or even the solenoid? https://postimg.cc/gallery/j59tLZT Thanks Quote Link to comment
