L20b emissions delete
Hey guys, I'm working on a 76 620. I have a Webber showing up tomorrow but I want to delete all the emissions crap while I'm in there. Couldn't find a good breakdown with the search on how, so figured I'd ask someone to point me to a couple good threads to read since I'm sure it's been posted a million times somewhere.
Thanks in advance.
  • Replies 22
Just know in advance that a poorly deleted emissions system can cause more problems than it's worth.  If you are expecting it to run better or make more power you're wasting your time. The emissions systems on old Datsuns have no effect at full throttle.
You can get rid of the EGR that is piggybacked onto the intake by removing it and making a cover or block off plate. These tend to look pretty hokey and unless you tap it you loose your PCV valve which is important for keeping your engine oil clean and prevent smells escaping into the cabin.  With a little work and some JB weld you can grind away on the intake and turn this...
into this...
Looks just like the earlier L16 intake but has the larger L20B runners and no EGR. Kept the PCV valve too.
The EGR signal from the carburetor passes through a thermal vacuum valve TVV on the thermostat housing. Remove and replace with a pipe plug.
The air pump can be removed and all the hoses and pipes. The metal pipes in the exhaust manifold can be unscrewed and removed and the holes plugged with these for a clean look...
Unless going to all this trouble it will look worse than just leaving it alone. No-one can see what you've done anyway.
  • Like 3
That's exactly what I need to know, what to keep and what to plug up! I'm more concerned with a clean engine that's easier to work on. Everything is so corroded that it will be easier to remove it than replace it at this point. Thanks Mike! You're a life saver buddy. I'll be posting updates on Instagram at @contained_chaoschaos180
So, I got the webber in today and deleted a bunch of clutter. She idles way better now but I'm getting a grinding noise from the front of the motor. I have a water pump on the way and I'll check the chain tensioner also. I'm going to look for a place to host photos so I can post pics of what I have done so far.
After a free temporary plugs here and there, she idles great!
Had to shave a little off the adapter plate and gasket.
Here's the before pic.
Now that it's all been test fitted and it works, I'll be disconnecting and pulling the engine to do gaskets and investigate the engine deeper. Also want to do cleanup and paint.
Plugs are metric thread. I just pulled them from another newer KA24E intake. The exhaust plugs I took one of the pipes with me to a fastener store and matched it to the one shown.
I see someone has already deleted the EGR but the bolt on manifold is still there. When removing it try hard to keep the PCV valve and the block vent connected.
Thanks Mike. The carb came with the block off plate so I removed what I could of the system and plugged anything I thought looked like it would cause a vacuum leak. Some plugs are temporary just so I could get it to idle and check some other things. More permanent solution coming soon and I plan to delete that rail on the manifold also.
2 hours ago, Eric said:
All L20B's have the emissions stuf on it? Or can i just buy a non emissions stuff L20B manifold and install that? Will clean up the engine bay a lot.
Pierce manifold sells a new intake, their website says it's for an L20b....
https://www.piercemanifolds.com/product_p/99002.825.htm
Not sure of its non emissions or not.... I would email them or call or maybe there are some other pics of that manifold on line.....
into this...
Do what I did, above. $7 for some JB weld and I think I bought a tap for the PCV valve, probably $10. The rest was just hand grinding away the aluminum with a carbide burr. Couple of hours and it looks exactly like an earlier L16 intake but has the larger L20B ports.
19 hours ago, Eric said:
pretty expensive manifolds, i'll go find something used first 🙂
$267 is expensive for a brand new intake manifold?
Considering a DGV adapter is $30-$40, you deduct that from the too expensive part. How much would you pay fore a nice manifold that meets all your criteria?
Well this is ratsun......
  • Like 3
Its not expensive for brand new manifold but thats not what i am looking for. I don't mind getting a used one for less money if it does the same thing
  • 3 weeks later...
Datzenmike, I plan on doing exactly this to my intake manifold.  I am using the Weber carb.  Do I plumb in a vacuum line attachment as well as a PCV valve?
At the time I did need a vacuum source for the ATC (auto temp control) on the air filter housing snorkel and for the purge for the charcoal canister. Why not have one and if not used just seal it for now?
  • 1 year later...
So other than the pressure valve.The other hose intlet has to come over also?? Does it matter where I stick the pcv like where the old egr port is instead of drilling out the nasty little port it was in?
