720kid Posted May 31, 2019 Report Share Posted May 31, 2019 Will a z22 crankshaft work in a z24 block my z22 block has a large crack in the #2 cylinder wall Quote Link to comment
wayno Posted May 31, 2019 Report Share Posted May 31, 2019 MY guess would be no it will not work in a stock Z24 block, the cranks are different, the Z24 has a longer stroke. 1 Quote Link to comment
datzenmike Posted May 31, 2019 Report Share Posted May 31, 2019 It should fit, as in bolt in...... but the Z24 block is 3/4" or 2cm taller. Your Z22 pistons would be too small a diameter. You could use Z24 or KA pistons but there is no rod long enough to make this work. For a 4mm shorter stroke crank you would need rods that are 2mm longer than the stock 165mm Z24 rods. Quote Link to comment
