crewdogch47 Posted May 31, 2019 Report Share Posted May 31, 2019 Hello to all !!! I am looking for the hump for the shifter boot. After installing the 4 speed I need to keep the water out . Any help would be great. Thanks again Quote Link to comment
BambooU Posted June 7, 2019 Report Share Posted June 7, 2019 What do you mean by the hump? Do you mean the bezel? Going from the transmission tunnel, there should be a bezel of some kind and a boot, and the boot snuggly fits around the stick. Do you mean the metal bezel or the rubber boot? If you mean the bezel, you'll need to find something that works specifically for the 510 transmission tunnel and the hole that you have. Is it the original hole in the tunnel? Is it a long-tail 4-speed? Is the hole still the same size? If not the stock hole, you'll probably need a bezel... The boot can go from there, and can even be a piece of leather until you find a nice rubber one. Quote Link to comment
