Bkcris13 Posted May 28, 2019 Report Share Posted May 28, 2019 I have a stock carb with no air cleaner on it. I’ve finally got it started but running at an extremely high idle. Mixing screw is back out all the way. Vacuum lines aren’t 100% sure if they’re correct but the pictures in the book or online do me no justice with everything having an air cleaner and I don’t. Quote Link to comment
Cheetahking Posted May 28, 2019 Report Share Posted May 28, 2019 Pics are useful - Mike should be able to help you with vacuum line routing. Quote Link to comment
Bkcris13 Posted May 28, 2019 Author Report Share Posted May 28, 2019 Can’t post any pictures without it being an url Quote Link to comment
Bkcris13 Posted May 28, 2019 Author Report Share Posted May 28, 2019 https://ibb.co/yN9V8wT Quote Link to comment
datzenmike Posted May 29, 2019 Report Share Posted May 29, 2019 Fast idle when the engine is warm?? It's normal for a cold engine to have a fast idle when the choke is on. There should be an electrical connector at the rear right of carb.. how many wires?? I see the PCV valve is there but no hose on it. It will run without it, but will run better in the long run with it. Same with the air filter housing, try to find one. Quote Link to comment
Bkcris13 Posted May 29, 2019 Author Report Share Posted May 29, 2019 Fast idle when I start it up. I have a video put canf post it Quote Link to comment
datzenmike Posted May 29, 2019 Report Share Posted May 29, 2019 So again what about when warmed up? Mixture adjusting should only be done when warmed up and the choke is off. Assuming the choke IS off and the idle is normal. Quote Link to comment
Bkcris13 Posted May 29, 2019 Author Report Share Posted May 29, 2019 Sounds like a lawn mover starting up. I mean i am running an open header right now as I’m fabricating new exhaust Quote Link to comment
Bkcris13 Posted May 29, 2019 Author Report Share Posted May 29, 2019 I don’t even let it run that long to be same due to it being at such a fast idle Quote Link to comment
Bkcris13 Posted May 29, 2019 Author Report Share Posted May 29, 2019 https://ibb.co/K0df66q 1 Quote Link to comment
bottomwatcher Posted May 29, 2019 Report Share Posted May 29, 2019 I see 4 empty vacuum ports and one unconnected hose. Amazing it runs at all! 1 Quote Link to comment
Bkcris13 Posted May 29, 2019 Author Report Share Posted May 29, 2019 That’s what I’m looking for a vacuum line diagram that doesn’t involve the air cleaner to hook up properly 1 Quote Link to comment
bottomwatcher Posted May 29, 2019 Report Share Posted May 29, 2019 Run a vacuum hose to the diaphragm on the distributor and plug the rest of the ports. The valve cover vent will run open to the atmosphere. You may or may not have an emissions diagram sticker stuck on the underside of the hood. 1 Quote Link to comment
datzenmike Posted May 29, 2019 Report Share Posted May 29, 2019 The brass fitting lower right @ about 4:00 o'clock needs plugging. The round 6 wire connector is for the ECC. (electronic controlled carburetor) It has a solenoid primary jet that varies it's open and closed state to adjust the mixture for best running and economy. To work properly, you need the O2 sensor in the exhaust manifold (you don't have) for feedback to the ECU under the driver's seat. The ECU calculates the mixture needed and adjusts the solenoid. Without the O2 sensor or any generalized system failure it reverts to an over rich 'limp home' mode. Terrible mileage and performance. This will be a nightmare to get running properly if at all. A regular Z24 carburetor would be the best bet or a new Weber. Quote Link to comment
Bkcris13 Posted May 29, 2019 Author Report Share Posted May 29, 2019 Okay so getting a Weber will do what with the ECU communicating that you’re talking about? 1 Quote Link to comment
Charlie69 Posted May 29, 2019 Report Share Posted May 29, 2019 Be sure you buy a real Weber not a Chinese knock off. I buy my Webers from Pierce Manifolds. Been doing business with them for over 3 decades. Pierce Manifolds Quote Link to comment
datzenmike Posted May 31, 2019 Report Share Posted May 31, 2019 California and maybe Arizona states require the ECC carburetor because of it's lower emissions and leaner fuel mixtures. In a way it half way between a carburetor and EFI. It uses electronics to adjust the fuel mixture as you drive. A regular carburetor is set and not adjustable. So you can try to find another ECC set up to replace the missing parts or perhaps another out of state Z24 carburetor or replace with a new Weber 32/36, about $300. What you'll do is remove the ECC carburetor and disconnect the ecu control altogether and replace it. 1 Quote Link to comment
Charlie69 Posted May 31, 2019 Report Share Posted May 31, 2019 I pass AZ emissions every 2 years with my Weber. If I fail I replace the CAT and retest. I have been emision testing it since I got back from Northern Nevada Christmas of 2012. Will not pass Cal emisions but this is one reason I do not live in Cal. I visit every year at least once. Quote Link to comment
