COOCHaDAMus Posted May 26, 2019 Report Share Posted May 26, 2019 do any of you fellow datsun gear heads know if a 75 datsun 620 windshield would fit on a 80 210. man these po-po's are getting kinda crazy pointing pistol for this. Quote Link to comment
datzenmike Posted May 26, 2019 Report Share Posted May 26, 2019 Shape is wrong. B-210 has square-ish bottom corners rounded tops. The 620 has rounded corners on all. 1 Quote Link to comment
bananahamuck Posted June 5, 2019 Report Share Posted June 5, 2019 Sent you a secret message . . 1 Quote Link to comment
az_rat210 Posted June 8, 2019 Report Share Posted June 8, 2019 I sourced a front windshield via a local shop that gets them from Mexico. Originally that was in '08 but about 4 years ago I had the same shop replace the windshield due to a crack. See if any of the shops in your area are able to source from there. The shop I used is AutoGlass Distributors (520) 573-1616 507 W Ajo Way, Tucson AZ. Give them a call if you need to and find out their connections maybe. 1 Quote Link to comment
