sondat Posted May 19, 2019 Report Share Posted May 19, 2019 (edited) Since both doors were gutted for body work and paint, today was the day to re-assemble. A lot of time passed since we dissembled and the reference pictures only helped so much. I am posting our assembly experience with many reference pictures for any one else tasked with this chore. First we started with the purchase of all new rubber and felt, I would have to look back almost 3 years to see where my son purchased the channel felt that runs the border of the window frame. As for the no draft window rubber and the felts/squeegees they were recently purchased on E-Bay from Australia. I looked briefly on Ratsun and found some help on the instal of the glass but was still struggling. Must have had the no draft glass and roll down glass in 5 or 6 times in different sequences, with and with out the perimeter felt in place but couldn't get both pieces of glass to fit. I'm sure there's other ways to achieve this but here's what ended up working for us. I should mention that this sequence works with or with out the door handle/latch mechanism in place because the first door we did had the latch mechanism in where as the other door didn't. -Started by installing the perimeter felt in the channel of the door (at back of door and top of window frame) also in channel of the no draft window frame. - Place the window crank mechanism in the door just laying at the bottom (facing the correct way). Then lower side glass into door using string at each end to cradle as well as being able to pull glass up when required. -This part is still a little tricky but you can see the no draft window going in at an angle. There is just enough room to have the channel felt in the no-draft window to engage the top front corner of the door glass. This is when you need to confirm that the back edge of the door glass is lined up with the groove of the felt at the back of the door. With this all lined up, as you lever the no draft window frame into place it forces (gently) the door glass into both front and back channel felt. -The pictures are hard to capture what's going on inside the door but hopefully my instructions are clear enough. Now the window can be pulled up using the strings then reach in through one of the access holes and grab the window crank mechanism, it needs to be fed between the tail end of the no-draft window channel and the threaded mount inside the door. The plastic wheel can now be slid into bottom of door glass channel. Once regulator spline is positioned through hole you can use handle to operate regulator to line up 4 mounting screw holes, then secure. -I've read that if there's too much padding when door cards are re-upholstered that the handles can rub and or not function properly. There is minimal foam under the vinyl but the handles still want to rub. I took a small rubber grommet just the right diameter and stuffed it into the female spline of the handles which still allows the spline to engage the handle but shims it out a little to avoid rubbing. -The guts of one door now complete, we installed poly over access holes then new upholstered door card. Edited May 19, 2019 by sondat 2 1 Quote Link to comment
Draker Posted May 19, 2019 Report Share Posted May 19, 2019 I've done this job before, can be a bit tricky. Thanks for posting. 1 Quote Link to comment
BrothersGarage Posted May 19, 2019 Report Share Posted May 19, 2019 Thanks for the pictures and the guide! 2 Quote Link to comment
530-521 Posted May 19, 2019 Report Share Posted May 19, 2019 That came out beautiful 2 Quote Link to comment
Greaser2 Posted May 22, 2019 Report Share Posted May 22, 2019 I just finished mine with new vent window rubber. The vents were flopping in the wind. Got it back together and tightened up on the springs till I thought they were tight enough but the vent still wants to close at higher speeds. Should I tighten more or is it hopeless? 1 Quote Link to comment
Charlie69 Posted May 22, 2019 Report Share Posted May 22, 2019 Tighten the rivet that holds wing window to wing window frame. 1 Quote Link to comment
Greaser2 Posted May 22, 2019 Report Share Posted May 22, 2019 14 hours ago, Charlie69 said: Tighten the rivet that holds wing window to wing window frame. I used a pop rivet so it’s fairly tight. I could try a small bolt however. 1 Quote Link to comment
Greaser2 Posted May 23, 2019 Report Share Posted May 23, 2019 23 hours ago, Charlie69 said: Tighten the rivet that holds wing window to wing window frame. Good call C. Replaced the rivet with a bolt and I got AC. 1 Quote Link to comment
