Greaser2 Posted November 23, 2020 Author Report Share Posted November 23, 2020 It is very stiff, it will likely break something at the pedal connection. 1 Quote Link to comment
d.p Posted November 23, 2020 Report Share Posted November 23, 2020 Look in my thread for the one I got. Roadster 200mm heavy duty 650kg clutch. Haven’t installed it yet but comes highly recommended. Going on an L20b and 79 ZX 5 speed. 1 Quote Link to comment
d.p Posted November 23, 2020 Report Share Posted November 23, 2020 F it here it is: https://www.ebay.com/itm/Datsun-Roadster-Exedy-Clutch-Kit-w-HD-600kg-Cover-fits-1600-2000-PL-510-521-620-/233202857988?_trksid=p2349624.m46890.l49292 1 Quote Link to comment
datzenmike Posted November 23, 2020 Report Share Posted November 23, 2020 Well it should be OK to use in the 2+2 and the 280zx. The only difference is your clutch master and slave and the mechanical advantage of your clutch pedal.. 1 Quote Link to comment
Greaser2 Posted November 23, 2020 Author Report Share Posted November 23, 2020 1 hour ago, d.p said: Look in my thread for the one I got. Roadster 200mm heavy duty 650kg clutch. Haven’t installed it yet but comes highly recommended. Going on an L20b and 79 ZX 5 speed. So you have a Roadster 200mm flywheel? 1 Quote Link to comment
Greaser2 Posted November 23, 2020 Author Report Share Posted November 23, 2020 1 hour ago, datzenmike said: Well it should be OK to use in the 2+2 and the 280zx. The only difference is your clutch master and slave and the mechanical advantage of your clutch pedal.. Yes, looking at what the master/slave setup is on the 2+2. 1 Quote Link to comment
datzenmike Posted November 23, 2020 Report Share Posted November 23, 2020 The 521 is 5/8" I couldn't find what the master is on the zx. There is also the mechanical leverage of the pedal. 1 Quote Link to comment
Greaser2 Posted November 23, 2020 Author Report Share Posted November 23, 2020 1 hour ago, datzenmike said: The 521 is 5/8" I couldn't find what the master is on the zx. There is also the mechanical leverage of the pedal. 5/8 as well. The slave is 3/4. I currently have a 11/16 slave. 1 Quote Link to comment
d.p Posted November 23, 2020 Report Share Posted November 23, 2020 (edited) I have a 6 bolt 200mm flywheel off an L20b out of a 610 IIRC. So no not a roadster but the same size. Edited November 23, 2020 by d.p 1 Quote Link to comment
Greaser2 Posted November 28, 2020 Author Report Share Posted November 28, 2020 So a 3/4 slave for the 280z fits perfectly on the dogleg. The pedal is significantly softer now, surprised how much of a difference 1/16 makes. 1 Quote Link to comment
mrbigtanker Posted December 2, 2020 Report Share Posted December 2, 2020 On 11/23/2020 at 5:22 AM, d.p said: I have a 6 bolt 200mm flywheel off an L20b out of a 610 IIRC. So no not a roadster but the same size. Bozo the L20B is a 6 bolt and L18/16 are 5 bolt. 1 Quote Link to comment
d.p Posted December 2, 2020 Report Share Posted December 2, 2020 (edited) 8 hours ago, mrbigtanker said: Bozo the L20B is a 6 bolt and L18/16 are 5 bolt. Ok? Greaser has an L20b in his truck and I have an L20b on a stand with 6 bolt flywheel. Bozo. Edited December 2, 2020 by d.p 1 Quote Link to comment
mainer311 Posted December 2, 2020 Report Share Posted December 2, 2020 (edited) Bozosoku? Edited December 2, 2020 by mainer311 1 Quote Link to comment
banzai510(hainz) Posted December 2, 2020 Report Share Posted December 2, 2020 simple to remember applies t L20 motors L20 in cars 200mm L20b in trucks 225 mm both 6 bolt trucks needed a heavier flywheel to help get it going. the stored energy mass 1 Quote Link to comment
d.p Posted December 2, 2020 Report Share Posted December 2, 2020 Lol tanker in here trying to drop knowledge and getting his ass paddled over it. 1 Quote Link to comment
mainer311 Posted December 2, 2020 Report Share Posted December 2, 2020 44 minutes ago, banzai510(hainz) said: simple to remember applies t L20 motors L20 in cars 200mm L20b in trucks 225 mm both 6 bolt trucks needed a heavier flywheel to help get it going. the stored energy mass You sure the flywheel is heavier? The 200 and 225 was only the clutch diameter, but the OD of the flywheel is the same. 2 Quote Link to comment
datzenmike Posted December 2, 2020 Report Share Posted December 2, 2020 But the engine side is scalloped on the lighter wheels. I think these are 240mm but also have a 225 from a z car and from a truck that look like this. Left is about 21 pounds and the right is about 29 pounds..... 2 Quote Link to comment
mrbigtanker Posted December 2, 2020 Report Share Posted December 2, 2020 46 minutes ago, d.p said: Lol tanker in here trying to drop knowledge and getting his ass paddled over it. You don't see me with a thousand questions on heredo you ? And no I don't pay everyone to work on my truck. Can you just finish it already it really is simple.Well maybe not for you. Quote Link to comment
mainer311 Posted December 2, 2020 Report Share Posted December 2, 2020 53 minutes ago, datzenmike said: But the engine side is scalloped on the lighter wheels. I think these are 240mm but also have a 225 from a z car and from a truck that look like this. Left is about 21 pounds and the right is about 29 pounds..... Hmmm, now I gotta take a look at the one that I got with my short block. I wanted to lighten it a little bit, but it may already be the lighter one. Quote Link to comment
banzai510(hainz) Posted December 2, 2020 Report Share Posted December 2, 2020 (edited) we all learn something new sometimes. No big deal. AI LEARNED THERE IS A 5 BOLT TRUCK FLYWHEEL THAT IS A 225MM but is rare and not really brought up. Mainer I got a 5 bolt that lighten to like 11pounds but I was scared to run . Thats why people use the Aluminum forged ones . The cast stock ones could get a crack and then go thru the trans tunnel and cut your legs off. I would give it away but don't want liablility issues. The guy who sold it to me said it was fine then I read on here you have to be careful. Edited December 2, 2020 by banzai510(hainz) Quote Link to comment
datzenmike Posted December 2, 2020 Report Share Posted December 2, 2020 1 hour ago, banzai510(hainz) said: we all learn something new sometimes. No big deal. AI LEARNED THERE IS A 5 BOLT TRUCK FLYWHEEL THAT IS A 225MM but is rare and not really brought up. Mainer I got a 5 bolt that lighten to like 11pounds but I was scared to run . Thats why people use the Aluminum forged ones . The cast stock ones could get a crack and then go thru the trans tunnel and cut your legs off. I would give it away but don't want liablility issues. The guy who sold it to me said it was fine then I read on here you have to be careful. Happened to Don Garlits. Took away part of his foot. One of the reasons he pioneered the driver in the front of the engine AA/F 'cars'. The one year only '74 620 with the L18 engine was 5 bolt and 225mm PP 12310-B7900 superseded to 12310-11W00 You can turn a regular L series down on a lathe to these dimensions. Round all corners and have balanced. There's a reason flywheels are the weight they are. It's to store kinetic energy used to get a heavy car going from a stop. Once moving it's of no use at all and absorbs engine power when accelerating that extra weight. Racing would be fine for almost no flywheel at all. Stop and go street car? Well if you like revving and slipping the clutch. I'm guessing my L20B is a 21 pound unit. I wouldn't go below 15. There's always someone that has a 9 pound aluminum wheel and claims he has no problem driving it. Just like loud exhaust... it's fine for some but gets tiresome really quick for others. 1 Quote Link to comment
banzai510(hainz) Posted December 2, 2020 Report Share Posted December 2, 2020 I have a 10pound alum and its fine. I didn't notice a HUGE improvement but got it used for 100$ 1 Quote Link to comment
njp.18 Posted July 13, 2021 Report Share Posted July 13, 2021 On 5/31/2019 at 8:48 AM, Greaser2 said: So, while waiting on wheels, finished up my steering wheel. My steering wheel was too far gone so decided to go with a Grant wood wheel. The Grant 4591 adapter fits great but leave a 1” gap so no horn or turn cancel. I found a 3.25” Dia. x 1.25” long 6061 aluminum stock for a spacer for $20 shipped . I used a exacto knife to carefully cut the glue holding the copper ring on the grant hub adapter. Took the aluminum to a local machine shop and had a recess milled in each end, one for the copper ring and the other end for the hub adapter. Then the center has milled out for $50. I then added 5 holes to the spacer, one for the horn wire, two for pins to cancel the turn signal and two I tapped for a screw to mount the adapter. painted the out edge, assembled everything on the column. Pretty happy, no gap and the horn and turn cancel work. why does the gap cause the horn and turn cancel not to work? 1 Quote Link to comment
DanielC Posted July 13, 2021 Report Share Posted July 13, 2021 The horn relay grounds through the steering shaft. With a gap,no ground. The pins have to flip a cam on the turn signal switch to cancel the turn signal. With a gap, the pins do not reach far enough to flip the cam that cancels the switch. 1 Quote Link to comment
