DanielC Posted April 19, 2020 Report Share Posted April 19, 2020 Why did the wires melt? Electrical short, or too close to exhaust? Reverse lights in a 521 are easy. There is a red with a black stripe wire that goes down to the reverse light switch, and the red with a black stripe wire continues out to the tail lights. One of the red with a black stripe wires is hot when the ignition is on. There is a separate small wiring harness on each tail light assembly. Because the tail light housings are made of plastic, each lamp in the assembly has a ground wire that goes to the metal frame of the tail light assembly. The tail light assembly is screwed to the bed of the truck, and the bed of the truck is bolted to the frame of the truck, and finally, the frame of the truck should be connected to the engine block. If you run a wire from the metal frame of each tail light assembly to the frame of the truck, and make sure the frame of the truck is grounded to the engine block, you will eliminate a lot of problems caused by bad grounds. Handy 521 wiring diagram. 2 Quote Link to comment
Greaser2 Posted April 19, 2020 Author Report Share Posted April 19, 2020 (edited) It’s about 12inch of the harness along the frame. It was near the muffler but not close. Looks to be an older short, I can see bare wires. I went ahead and pulled the entire body harness out. Edited April 19, 2020 by Greaser2 2 Quote Link to comment
Greaser2 Posted April 25, 2020 Author Report Share Posted April 25, 2020 Installed my brand new rear body harness this morning. All my lights are back to normal. 3 Quote Link to comment
banzai510(hainz) Posted April 26, 2020 Report Share Posted April 26, 2020 Where you buy the harness? or this a DIY kit? 1 Quote Link to comment
Greaser2 Posted April 26, 2020 Author Report Share Posted April 26, 2020 Made it. 3 Quote Link to comment
Greaser2 Posted June 2, 2020 Author Report Share Posted June 2, 2020 Anyone have a heater core. Don’t need the whole box. 1 Quote Link to comment
Charlie69 Posted June 2, 2020 Report Share Posted June 2, 2020 (edited) Picture of your heater core please. I have 2 heaters. Edited June 2, 2020 by Charlie69 2 Quote Link to comment
Greaser2 Posted June 2, 2020 Author Report Share Posted June 2, 2020 16 hours ago, Charlie69 said: Picture of your heater core please. I have 2 heaters. Is this pic good enough? It is out of a 67 411 but they are almost identical so I think a 521 would fit just fine I have a hairline crack on one of the pipe ends 1 Quote Link to comment
d.p Posted June 2, 2020 Report Share Posted June 2, 2020 I have one from a 510 but don't know if its the same? 2 Quote Link to comment
Greaser2 Posted June 3, 2020 Author Report Share Posted June 3, 2020 I don’t see the core so not sure if it will fit DP 1 Quote Link to comment
d.p Posted June 3, 2020 Report Share Posted June 3, 2020 I took it out and the pipes go in different directions than ours so I don't think it will work. Looks like this: 1 Quote Link to comment
Greaser2 Posted June 3, 2020 Author Report Share Posted June 3, 2020 Nope. Thanks anyway 1 Quote Link to comment
Charlie69 Posted June 3, 2020 Report Share Posted June 3, 2020 (edited) I will go over to where I have the heaters in storage today. Shoot me a picture of the motor also please. I had 3 heaters and each heater had a different style motor. Crashtd420 got the the flat motor heater. Edited June 3, 2020 by Charlie69 2 Quote Link to comment
Charlie69 Posted June 5, 2020 Report Share Posted June 5, 2020 (edited) I will be over to pick up the Heaters tomorrow for sure, life got in the way today. Not sur from your picture but I am guessing you have the longer motor. Edited June 5, 2020 by Charlie69 1 Quote Link to comment
Charlie69 Posted June 5, 2020 Report Share Posted June 5, 2020 After looking at your picture again I think you have the medium length motor by the shape of the end of it. Quote Link to comment
Greaser2 Posted June 5, 2020 Author Report Share Posted June 5, 2020 It’s 5 inch long. Put it works, it the heater core I’m in need off. 2 Quote Link to comment
Charlie69 Posted June 6, 2020 Report Share Posted June 6, 2020 Yes I know you need the heater core. The heaters will be delivered tomorrow and I will see if the heater core will hold 15 lbs of pressure. 1 Quote Link to comment
gene knight Posted June 6, 2020 Report Share Posted June 6, 2020 1 minute ago, Charlie69 said: Yes I know you need the heater core. The heaters will be delivered tomorrow and I will see if the heater core will hold 15 lbs of pressure. charlie69: are you gonna be home thru out the day cuz i wanna stop by and get your input on my headlight issues 1 Quote Link to comment
Charlie69 Posted June 6, 2020 Report Share Posted June 6, 2020 I am leaving town this morning and will not be back until late afternoon or early evening. 1 Quote Link to comment
Charlie69 Posted June 10, 2020 Report Share Posted June 10, 2020 I appologize it took so long and am sorry to say the heater core I have is shot. Has more leaks than I have ever seen in a heater core. 1 Quote Link to comment
Greaser2 Posted June 10, 2020 Author Report Share Posted June 10, 2020 No problems. 1 Quote Link to comment
Greaser2 Posted June 16, 2020 Author Report Share Posted June 16, 2020 So I have 4” lowering blocks and two splines on the front. Pretty low for stock suspension. And or course, the ride is ruff. Looking around for some nice shocks but everything looks pretty basic. Assuming shock can improve the ride, what is out there? I figure someone has some experience. 2 Quote Link to comment
