Greaser2 Posted March 29, 2020 Author Report Share Posted March 29, 2020 And interior back in. And a cheesy pool ball shifter. 5 Quote Link to comment
BrothersGarage Posted March 30, 2020 Report Share Posted March 30, 2020 Man that interior looks awesome, everything is mint! Why didn't you match the shift knob to the bitch knob and go full green sparkle? 1 Quote Link to comment
pidge Posted March 30, 2020 Report Share Posted March 30, 2020 I really like that interior. I’ve been looking at plaid truck bench pics for a while. Nice job man. -Pidge 2 Quote Link to comment
d.p Posted March 30, 2020 Report Share Posted March 30, 2020 17 hours ago, Greaser2 said: Yes. Same guy. I got loop so maybe it will be fine. And yes, I will likely get another mat for driving. Did he do the loop mats for you? If so fuck me I wish I would have known. 2 Quote Link to comment
Greaser2 Posted March 30, 2020 Author Report Share Posted March 30, 2020 29 minutes ago, d.p said: Did he do the loop mats for you? If so fuck me I wish I would have known. Yes. I asked specifically for loop as I like the look. 1 Quote Link to comment
Greaser2 Posted March 30, 2020 Author Report Share Posted March 30, 2020 What’s the best way to confirm oil pressure. I turn over the engine with no plugs and oil light stays on. Maybe it should. I don’t see oil flowing through the valve cover hole. 1 Quote Link to comment
Crashtd420 Posted March 30, 2020 Report Share Posted March 30, 2020 (edited) Wasn't this kind of a fresh motor? It might take a minute to fill the oil filter.... You could crack the filter loose just enough to see if oil is in the filter... Then I would probably do the same at the oil sender.... Some oil should drip out of those locations..... Edited March 30, 2020 by Crashtd420 1 Quote Link to comment
Greaser2 Posted March 31, 2020 Author Report Share Posted March 31, 2020 I loaded the filter and pump already 1 Quote Link to comment
Greaser2 Posted March 31, 2020 Author Report Share Posted March 31, 2020 I let it start for ten seconds. Then a second 10 seconds. Then a third. Light went off at 8 sec. on the 4th, light went out at 2 secs so think I’m good. 1 Quote Link to comment
Charlie69 Posted March 31, 2020 Report Share Posted March 31, 2020 Some times you have to rev your engine to get the old alternators to start charging. Quote Link to comment
banzai510(hainz) Posted March 31, 2020 Report Share Posted March 31, 2020 I think he meant oil light 1 Quote Link to comment
datzenmike Posted March 31, 2020 Report Share Posted March 31, 2020 My starter oil pressure is over 30. The light should go out above 8 PSI. It does take a while on a fresh start up but once everything is primed.... after that it's just a few seconds. 1 Quote Link to comment
greenthumb Posted March 31, 2020 Report Share Posted March 31, 2020 12 hours ago, Greaser2 said: Yes. I asked specifically for loop as I like the look. Was this off eBay or ? Got a contact? 1 Quote Link to comment
Greaser2 Posted March 31, 2020 Author Report Share Posted March 31, 2020 Brownstreethodrods09 on eBay. Or email is shouldabeenhotrods@gmail.com. I contacted him by email. 1 Quote Link to comment
Charlie69 Posted March 31, 2020 Report Share Posted March 31, 2020 (edited) On 3/30/2020 at 5:33 PM, banzai510(hainz) said: I think he meant oil light Thank you I missed that he was talking oil light. Ignor my post, please carry on! LOL Edited April 1, 2020 by Charlie69 Quote Link to comment
d.p Posted March 31, 2020 Report Share Posted March 31, 2020 (edited) 9 hours ago, Greaser2 said: Brownstreethodrods09 on eBay. Or email is shouldabeenhotrods@gmail.com. I contacted him by email. That is the guy. Greaser did you wrap your dash or have it restored? Edited March 31, 2020 by d.p 2 Quote Link to comment
Greaser2 Posted March 31, 2020 Author Report Share Posted March 31, 2020 PO wrapped it in marine grade vinyl. Did a good job too. 1 Quote Link to comment
greenthumb Posted April 1, 2020 Report Share Posted April 1, 2020 Thanks for the contact info. Are you happy with the loop carpet with regard to how it fits over the tunnel contours? 1 Quote Link to comment
Greaser2 Posted April 1, 2020 Author Report Share Posted April 1, 2020 13 hours ago, greenthumb said: Thanks for the contact info. Are you happy with the loop carpet with regard to how it fits over the tunnel contours? With the curves I was concerned as well and was willing to live with some creases but I was surprised how easily the tunnel piece layed/glued down. No creases. The carpet is light weight. The kit comes in seven pieces so that helps with all the curves. Take your time. Test fit, test fit, test fit. 1 Quote Link to comment
mainer311 Posted April 1, 2020 Report Share Posted April 1, 2020 Did you use any portion of the vinyl liner mat at all? Even up near the firewall? Also, how much was the loop carpet kit, if you don't mind me asking. 1 Quote Link to comment
d.p Posted April 1, 2020 Report Share Posted April 1, 2020 I cant answer your question but I do know for just the 2 loop floor mats its $225. I didn't get loop anything and the carpet is holding up great but the floor mats can be a bitch if you are picky. If I could do it again I would have gotten loop floor mats and left the carpet the same (whatever its called). 1 Quote Link to comment
Greaser2 Posted April 1, 2020 Author Report Share Posted April 1, 2020 1 hour ago, mainer311 said: Did you use any portion of the vinyl liner mat at all? Even up near the firewall? Also, how much was the loop carpet kit, if you don't mind me asking. I stopped at the firewall insulation. Like DP says, Carpet is $225. Mats are another $200. 4 Quote Link to comment
Charlie69 Posted April 1, 2020 Report Share Posted April 1, 2020 That looks really good! Quote Link to comment
mainer311 Posted April 1, 2020 Report Share Posted April 1, 2020 Nice. Looks like he changed his pricing around a little, but there's no one else out there making them. Just ordered a set w/o mats. 1 Quote Link to comment
Greaser2 Posted April 1, 2020 Author Report Share Posted April 1, 2020 (edited) And like DP I did fat mat too. And don’t trim off extra material from the tire hump and tunnel area. Let the extra lay into the floor pan area. The floor pan pieces will cover. Edited April 1, 2020 by Greaser2 1 Quote Link to comment
