pondking Posted May 14, 2019 Report Share Posted May 14, 2019 Anybody have a list for parts needed to convert NONLSD R200 Differential into a LSD diff? Any recommendations? Quote Link to comment
G-Duax Posted May 15, 2019 Report Share Posted May 15, 2019 You will need thee LSD of course, with the correct splines for your axles. Those things come in several different spline counts. I have an R200 Nismo LSD sitting here that come all the way from Japan at my expense, that is for the big R34 GT-R splines. Unfortunately, it was supposed to be for something else, like a 29 spline S13, or a 30 spline S15. All I've ever used it for in the past 10 years is parts...... Funny, the plates in it were a perfect match for the H190 I have in my truck. Then you should have new seals, and a good selection of bearing shims so you can properly set gear mesh. Wait, you didn't know the bearings had to be re-shimmed ? Better plan on taking it to a dealer then to have it them set it up. Quote Link to comment
