Smardo Posted May 14, 2019 Report Share Posted May 14, 2019 Installing Weber on j13 of 65 520. Had Nikki carb before. Got kit etc. What throttle cable will work on new install? Quote Link to comment
banzai510(hainz) Posted May 14, 2019 Report Share Posted May 14, 2019 (edited) On my 521 I just swapped the Hitachi stock carb linkage to the weberDGV. used same cable but I'm not familiar with the J motors. I had to slot the cable support bracket or move the hole so the cable flows thru to the carb cable groove Rock auto interior section has throttle cables for the 521 Edited May 14, 2019 by banzai510(hainz) Quote Link to comment
Stoffregen Motorsports Posted May 14, 2019 Report Share Posted May 14, 2019 You can get a generic cable linkage kit from companies like Pierce Manifolds. A kit for an MGB would have the linkage piece that goes on the throttle shaft and the cable holder that mounts to the carb. I just googled "weber dgv cable throttle kit" and found a bunch of ideas. https://www.google.com/search?q=weber+dgv+cable+throttle+kit&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjni5ih8pviAhUollQKHX9jDU8Q_AUIDygC&biw=1680&bih=908#imgrc=_ Quote Link to comment
