PNW 720 97499 Posted May 14, 2019 Report Share Posted May 14, 2019 I just lost 5th and reverse today in my 5-speed. How do I identify which tranny I have? I have two parts trucks, both with 5 speeds, one 2wd, one 4wd. I would prefer to use the 2wd trans, if possible to just swap the adapter and transfer case. Any thoughts or help is greatly appreciated in this. I was going to have a work mech pull the trans tonight or tomorrow night after work, and install this weekend ) if the other 4 gears hold up and I don't grenade the tranny). 1 Quote Link to comment
datzenmike Posted May 14, 2019 Report Share Posted May 14, 2019 Length. The 720 had 26" and 31.5" lengths so easier if they are the same length. Ratios. Four wheel drive have a wide ratio with a lower first gear for a slower crawl speed. Two wheel drive are a mid ratio. They will work just fine in a 4x4 but if you seriously off road it you will loose some gearing advantage. 41 minutes ago, PNW 720 97499 said: I would prefer to use the 2wd trans, if possible to just swap the adapter and transfer case. ????? If both parts trucks have Z series engines, and if the length is alright, the transmission will drop right in, there is nothing to change. 1 Quote Link to comment
PNW 720 97499 Posted May 14, 2019 Author Report Share Posted May 14, 2019 Thanks for the info! I was worried about having a married transfer case. I don’t do serious off road or crawling. More for snow and light off road 1 Quote Link to comment
PNW 720 97499 Posted May 14, 2019 Author Report Share Posted May 14, 2019 Also, could I swap the end adapters if the lengths are different? How would I overcome the difference? Would I need to get the prop shaft lengthened/shortened? Quote Link to comment
datzenmike Posted May 14, 2019 Report Share Posted May 14, 2019 The 720 uses a divorced transfer case so you can swap any transmission you like in and it remains uninfected. Measure the lengths first. You cannot convert a 26" into a 31.5" length without also replacing the mainshaft inside. Forget about this. 1 Quote Link to comment
PNW 720 97499 Posted May 14, 2019 Author Report Share Posted May 14, 2019 Damn, ok. I’ll take a look tomorrow. I appreciate the info. I think the Haynes is lacking in info... 1 Quote Link to comment
wayno Posted May 14, 2019 Report Share Posted May 14, 2019 The only time I had this happen was when a bearing out of the cluster gear bearing went thru the gears and broke the cluster gear shaft at the rear bearing on the rev/5th side, I lost rev/5th gears, the whole truck shuttered violently when it happened, it squealed briefly about a minute before, I turned around to go home as I was 5 blocks away from home, if I had stopped I likely could have rebuilt the transmission, but after that bearing went thru the gears it became a parts transmission, oil puked out everywhere as the rear case got damaged at the same time. I learned that day that if it starts making really bad squealing noises to stop and shut it down, remove the drive line from the rear axle so the transmission does not turn, then tow it home and remove the transmission to replace the cluster gear bearing, if you drive it you can destroy the transmission. Do you have a console in your truck? If you do does it have a change tray in front of the shift lever, if it does you have a long shaft, if it does not have a place for change you have a short shaft. 1 Quote Link to comment
datzenmike Posted May 14, 2019 Report Share Posted May 14, 2019 Fifth and reverse are on the same fork in the rear case of the transmission. Maybe the roll pin in the fork sheared off, maybe the mainshaft nut came loose. (although it's now staked in place on the later 71B transmissions) Either way I would think fixable at the moment. 1 Quote Link to comment
PNW 720 97499 Posted May 27, 2019 Author Report Share Posted May 27, 2019 So I have the short trans. My parts trucks both have the long trans. I have a long pulled out already. It seems as though I’m up shits creek. I’ll have to check the wrecking yard and see if I can work a deal out 1 Quote Link to comment
PNW 720 97499 Posted May 27, 2019 Author Report Share Posted May 27, 2019 Also, before completely pulling my short trans, saw my problem: a nice hole in the side of the case. I was fortunate 2, 3, and 4 worked for two weeks. But at least now I have a ‘65 beetle to cruise while the truck gets fixed 1 Quote Link to comment
datzenmike Posted May 28, 2019 Report Share Posted May 28, 2019 If you use a long 5 speed maybe use that shorter driveshaft???? 1 Quote Link to comment
PNW 720 97499 Posted May 28, 2019 Author Report Share Posted May 28, 2019 The yoke doesn’t match, and I’ll need a console. Gotta check the junkyard’s pickup 1 Quote Link to comment
datzenmike Posted May 29, 2019 Report Share Posted May 29, 2019 The transmission splines should all be the same or you mean the differential yoke? 1 Quote Link to comment
PNW 720 97499 Posted May 29, 2019 Author Report Share Posted May 29, 2019 (edited) Yoke to the transfer case of the prop shaft. The shorty has a larger diameter and different bolts. Junkyard had a shorty, but say it needs rebuilt. Any idea which trans number it is from the Haynes so I know which rebuild kit to get? Edited May 29, 2019 by PNW 720 97499 1 Quote Link to comment
bottomwatcher Posted May 29, 2019 Report Share Posted May 29, 2019 Two universal joints is all you need to rebuild it. Several posts on u joints in the 720 forum. 1 Quote Link to comment
PNW 720 97499 Posted May 29, 2019 Author Report Share Posted May 29, 2019 The prop shafts are different diameters and lengths overall. I was thinking just changing the yokes on the t-case if it comes down to it and I can’t rebuild the trans from the wrecking yard 1 Quote Link to comment
datzenmike Posted May 29, 2019 Report Share Posted May 29, 2019 I changed the receiver yoke on the trans case. 1 Quote Link to comment
