Greaser2 Posted May 11, 2019 Report Share Posted May 11, 2019 My 521 has an electric pump under the hood. Want to move it near the tank or just go back to stock. Plan on doing Weber’s. What do u guys recommend? 1 Quote Link to comment
mklotz70 Posted May 11, 2019 Report Share Posted May 11, 2019 In case you don't know.....do a bit of research, or maybe someone will chime in. The weber's don't like much fuel pressure so it's common to put a regulator inline before the carb. 1 Quote Link to comment
Greaser2 Posted May 11, 2019 Author Report Share Posted May 11, 2019 26 minutes ago, mklotz70 said: In case you don't know.....do a bit of research, or maybe someone will chime in. The weber's don't like much fuel pressure so it's common to put a regulator inline before the carb. I did some searching and the posts are years old. It’s doable either way but looking for an opinion that isn’t 5 years old. 1 Quote Link to comment
datzenmike Posted May 11, 2019 Report Share Posted May 11, 2019 If it works fine right now it will work just fine if you move it to the rear... or leave it. It may be quieter if moved outside. Liquid pumps can be made to push almost any pressure but they suck at sucking because they are limited by atmospheric pressure of 14.7 PSI. No pump made can suck up hill over about 30 feet so the lower the pump is to the fuel tank the easier it is for it to work. Mechanical pumps are almost level with the carburetor but have unlimited power to run them and are not going to over heat. 2 Quote Link to comment
mainer311 Posted May 12, 2019 Report Share Posted May 12, 2019 Stock mechanical pumps are very hard to find now, or very expensive. I recently put an aftermarket mechanical on mine and it seems to be working okay. 1 Quote Link to comment
datzenmike Posted May 12, 2019 Report Share Posted May 12, 2019 I've never had a mechanical L series pump fail or give any problems. If I ever did need one all I have to do is cut the back yard. 2 Quote Link to comment
mainer311 Posted May 12, 2019 Report Share Posted May 12, 2019 Hahaha. My last one blew the lower diaphragm, and I couldn’t find a rebuild kit. 1 Quote Link to comment
banzai510(hainz) Posted May 13, 2019 Report Share Posted May 13, 2019 There are still the Blackstone Mexico ones with the gold cap. seem to work OK. for about 30$ 1 Quote Link to comment
Greaser2 Posted May 21, 2019 Author Report Share Posted May 21, 2019 I went ahead and removed the electric fuel pump and put in a new mechanical fuel pump. The stock mech was shot. Truck doesn’t know the difference. 2 Quote Link to comment
