Control arm, idler arm clearance.
isomswim
Bit of weird issue. I've been working on my '79 for what seems like forever. I'm starting to put the front axle, suspension and steering back together. I got a new idler arm for the steering but when I go to bolt it up I am contacting the control arm. I'm not sure if 78-79 has a different mounting point than 72-77/78. Anyone with a 79 got any pictures of the mounting and clearance of the idler arm.
  • Replies 15
7 minutes ago, Stoffregen Motorsports said:
I do know that the 720 has a steering box and idler arm that mount outside the frame. Is it possible you got the wrong one?
No it's a completely different look and style that the 720 from what I can tell with a quick Google search. I have another one on order that is the "correct" number match for the year model but my other option is to trim the control arm
I have a 1973 620, and the orientation of your idler arm looks like what I remember for the 1973. I currently have the tie rod and idler arm off so I can't do a direct comparison.
Don
G-Duax got some real good pics of the 1973 idler arm and the clearances to the lower control arm. Plenty of space between the lower control arm and the idler arm, somewhere around an inch. Isomswim, how much space do you have between the idler arm and the lower control arm? How long is your idler arm? What is the length of the movable part of the idler arm from the collar up next to the pivot? From that same collar, what is the distance to the lower control arm? Can you get pics of where you measured from?
Don
When you install it, do yourself a favor and put the upper bolt in from the outside of the frame, tighten both of them down, and weld the other nut to the new idler arm bracket.  Since you need to drop the steering to remove/install the engine, this makes the job a little easier.
  • Like 3
