89Sunny Posted April 14, 2019 Report Share Posted April 14, 2019 Does anyone here run adjustable rear leaf spring shackles in the front? I bought some rear leaf springs for an older 1200 and they do not line up. They told me to notch where it connects in the front so I did and the pin still does not line up. Quote Link to comment
89Sunny Posted April 14, 2019 Author Report Share Posted April 14, 2019 I might have just figured out a solution unless someone tells me I'm stupid. Can I just drill a new hole and move the pin up to the correct location? Quote Link to comment
89Sunny Posted April 14, 2019 Author Report Share Posted April 14, 2019 2nd thought: I have lowering blocks that go with this too so I was thinking of making new blocks. Center the pin (read welded on bolt) on the top and relocate the hole on the bottom to accept the new spring pin location. Or does this NEED to be centered? Quote Link to comment
datzenmike Posted April 14, 2019 Report Share Posted April 14, 2019 Leave the old pin in place to keep structurally sound. Bad enough to drill more holes but you don't want it to start any fractures. I guess the lowering block off set would work. Don't forget the rear axle is held in place (against side to side movement ) by the rigidity of the two spring packs and the centering of forces on the pin. The pin that is now indirectly connected to the leaf pack and through an off set on the lowering block. Make sure the U bolts are tight and check now an then that the block is not shifting.. Quote Link to comment
89Sunny Posted April 14, 2019 Author Report Share Posted April 14, 2019 Thanks!! So do you think 3/16 wall is thick enough? BTW and completely off subject my family and I will be vacationing up your way this summer. Quote Link to comment
datzenmike Posted April 14, 2019 Report Share Posted April 14, 2019 For blocks? I guess so if not too tall and see about making them slightly wedge so the driveshaft angles are preserved. Lowering always disturbs the drive shaft angle in and out and results in vibration. Quote Link to comment
89Sunny Posted April 14, 2019 Author Report Share Posted April 14, 2019 This was just sent from the seller so i guess I'll do this first. It's free and easy Hi Todd Yes do the other side. The reason this side won’t line up is due to the other side standard spring pulling the diff forward due to the ark the spring gets in it when unloaded. You will probably notice that the other side wheel isn’t sitting in the centre of the wheel arch when it’s jacked up like it is. The new springs won’t flattern out as much when loaded so there won’t be as much difference in wheel movement between loaded and unloaded. Quote Link to comment
datzenmike Posted April 14, 2019 Report Share Posted April 14, 2019 lol. Well there is that. I figured you had both springs on. Quote Link to comment
wayno Posted April 14, 2019 Report Share Posted April 14, 2019 (edited) You have a drive line in this equation also, you cannot pull the yoke out of the transmission very far without major issues. Do you have the leaf spring backwards meaning the front eye towards the rear? Edited April 14, 2019 by wayno 1 Quote Link to comment
89Sunny Posted April 15, 2019 Author Report Share Posted April 15, 2019 2 minutes ago, wayno said: You have a drive line in this equation also, you cannot pull the yoke out of the transmission very far without major issues. Do you have the leaf spring backwards meaning the front eye towards the rear? Now I admit that I am not that smart when it comes to this truck BUT i do have the spring on correctly. The big eye in the front just as it came off. 🙂 @datzenmike Well I could not get the first one too fit right I did not want to cut more to try to get the 2nd one to fit. I'm learning .. Quote Link to comment
wayno Posted April 15, 2019 Report Share Posted April 15, 2019 OK, I have never seen a Datsun/Nissan leaf spring with 2 different sized eyes before, and I have had them backwards once, but switched it around once I figured it out. Quote Link to comment
datzenmike Posted April 15, 2019 Report Share Posted April 15, 2019 I thought the fronts were larger eyelets? Quote Link to comment
wayno Posted April 15, 2019 Report Share Posted April 15, 2019 I just learned something today, they are different sizes, I never even noticed this before, I just knew what end was what, although I have got a 4wd 720 leaf backwards before, don't know how I did that if they are different sizes. Quote Link to comment
datzenmike Posted April 15, 2019 Report Share Posted April 15, 2019 All 521/620/620 (maybe others) are 1200mm long when flattened out. Quote Link to comment
89Sunny Posted April 17, 2019 Author Report Share Posted April 17, 2019 Well after taking everything loose/off and having everything balanced on a jack I finally got the springs on and everything lined up. (with blocks). I have to go over everything and tighten it tonight. Thanks again everyone for your help. Quote Link to comment
