Vic Posted September 11 Report Share Posted September 11 Hi Wayno. I just saw this genius adapter plate you came up with. I know it’s an old post but just wondered if you ever did any more with fabbing up some of these plates? I have a J13 in my 1964 320 with a 4 speed and I also have a 63A#2 short 5 speed to swap into it. Let me know if you have a plate and if so can you give me an idea of the cost? Thanks! Vic 1 Quote Link to comment
Stoffregen Motorsports Posted September 11 Report Share Posted September 11 Wayno doesn't come around much anymore. You may want to pm him so he gets an email notification. Quote Link to comment
wayno Posted September 12 Author Report Share Posted September 12 I have not done anything with this since 2019, I have one plate on the running J15 I have on a stand with the adapter and transmission installed. I found a bunch of plates on a shelf a couple days ago, I will need to look at them, as I recall I sold all the ones I made and it is a major pain to make that 4" hole for the starter for me, I believe I made the master using the J15 plate and a L block plate, and I will assure you that there is only about a 1/4" or less to work with for distributor/starter clearances working an L block transmission, I could see no way to make a Z block transmission work. There are other things involved like a washer needed on the ball the clutch arm to move it out slightly for the clutch to work, I likely mentioned this in this thread but did not read it to remember everything, in the end I do not want to make any more plates as there is not a great need for them, if there was a need I would take the one I have out and see how much it would cost to make copies, I cannot make the CAD program or whatever it is called myself. 1 Quote Link to comment
bananahamuck Posted Wednesday at 05:02 PM Report Share Posted Wednesday at 05:02 PM On 9/10/2024 at 9:22 PM, Vic said: Hi Wayno. I just saw this genius adapter plate you came up with. I know it’s an old post but just wondered if you ever did any more with fabbing up some of these plates? I have a J13 in my 1964 320 with a 4 speed and I also have a 63A#2 short 5 speed to swap into it. Let me know if you have a plate and if so can you give me an idea of the cost? Thanks! Vic Installed on page 15 of my build i am going to send you a DM clickity clickity Quote Link to comment
bananahamuck Posted Wednesday at 05:33 PM Report Share Posted Wednesday at 05:33 PM It would seem after typing out a novel in messages ,,,,,,,,,,,, the site says you can't receive any messages Quote Link to comment
