ZeroTwo510 Posted April 11, 2019 Report Share Posted April 11, 2019 Just bought this guy yesterday,1983 Nissan Maxima thats been sitting since 1992(last year tagged),2.8L diesel with 5 speed FS5W71B ๐,gonna pull the 5 speed and slap it in my A10. Will my 3 speed auto bolt onto this behemoth? I actually got the engine running again and am thinking of either keeping the diesel since it's a bit cheaper to buy right now than standard gas or swapping in another engine and keep it as a daily. Any swap info you guys can share with me in regards to suspension and engine? ย ย 1 Quote Link to comment
datzenmike Posted April 11, 2019 Report Share Posted April 11, 2019 Transmission won't work in the A10 as is. The A10 automatic won't fit the Diesel also. The diesel starter is on the left or driver's side. ย I have Maxima struts and calipers on my 710 and love them!!! They are slightly shorter (so bonus lowering) massive calipers and have vented rotors just a hair smaller diameter than the 280zx too! Really nice up grade but you may need 14" rims to clear the calipers. If those are factory mags USE EM! You should also use a 15/16" master cylinder, however the Maxima mastersย have horizontal bolt mountings and won't fit most Datsuns. ย Quote Link to comment
ZeroTwo510 Posted April 11, 2019 Author Report Share Posted April 11, 2019 Oh no I meant my l20b A10(510) datsun ๐ nice! I'll have to customize mine now! ๐ yeah i noticed these brakes are pretty big,it even has disc brales in the rear. They are stock mags! Definitely will re-use! I'll look into brake setups definitely since the one on here now is all seized and rusted ๐ this thing was full of a bunch of spare parts too,2 exyra diesel pumps,and extra starter and alternator,it even had two brand new oil filters from wayyyy back inside the trunk. I'll post more pictures of it tomorrow in daylight for you guys ๐ Quote Link to comment
datzenmike Posted April 11, 2019 Report Share Posted April 11, 2019 10 hours ago, ZeroTwo510 said: ย with 5 speed FS5W71B ๐,gonna pull the 5 speed and slap it in my A10. Will my 3 speed auto bolt onto this behemoth?ย ย ย ย ย 7 hours ago, ZeroTwo510 said: Oh no I meant my l20b A10(510) datsun ๐ nice!ย ย ย To be clear the Maxima transmission has an SD diesel bolt pattern with the starter on the left or driver's side so this won't work on any of the other L series engines. Likewise the L series automatic won't work on the diesel. Hang onto the transmission though. 1 Quote Link to comment
ZeroTwo510 Posted April 12, 2019 Author Report Share Posted April 12, 2019 18 hours ago, datzenmike said: ย ย ย To be clear the Maxima transmission has an SD diesel bolt pattern with the starter on the left or driver's side so this won't work on any of the other L series engines. Likewise the L series automatic won't work on the diesel. Hang onto the transmission though. ย I had the chance to pull out the transmission today and I think it will fit,not sure if maybe the previous owner swapped transmission since the starter was rigged to a momentary switch apart from the actual ignition switch. Here I'll show you some pictures now. Quote Link to comment
ZeroTwo510 Posted April 12, 2019 Author Report Share Posted April 12, 2019 18 hours ago, datzenmike said: ย ย ย To be clear the Maxima transmission has an SD diesel bolt pattern with the starter on the left or driver's side so this won't work on any of the other L series engines. Likewise the L series automatic won't work on the diesel. Hang onto the transmission though. ย Here's the engine ๐ ย 1 Quote Link to comment
ZeroTwo510 Posted April 12, 2019 Author Report Share Posted April 12, 2019 On the other hand the front main bearing was broken and metal shavings were everywhere,is the front gear supposed to be tapered like that or is that the result of the broken bearing? 5 ball bearings came out when I drained it and I assume the rest turned into mush. How difficult would it be to replace this bearing? I have a shop press here so just a matter of doing it. And on the the front cover that bolts inside the bellhousing,it got damaged too and I was wonderimg if the plates off a 71c transmission areย the same? I rather replace it since I feel it will leak gear oil through here.ย All the other gears look ok just that front one that's tapered ๐ 1 Quote Link to comment
datzenmike Posted April 12, 2019 Report Share Posted April 12, 2019 That's definitely NOT a diesel transmission. Interesting that someone tried a right hand starter on it. Never thought of this. ย The input bearing is toastestro. should look like this... ย ย Can you take pictures of the transmission case? top and back? 1 Quote Link to comment
ZeroTwo510 Posted April 15, 2019 Author Report Share Posted April 15, 2019 Gahhh sorry I haven't been active in a few days,work has been busy and i haven't had a chance to tinker with the Maxima. I'll have those pictures tomorrow though ๐ quick question,do you guys think the strut assembliesย from this maxima will bolt onto my 1978 datsun 510 coupe? I was planning on swapping s13 suspension onto this car and maybe using the brakes and struts from this car in my A10 since these brakes are vented and bigger than the stock solid brakes I have on the 510 now. Quote Link to comment
ArchetypeDatsun Posted April 15, 2019 Report Share Posted April 15, 2019 Nice to see another maxima owner should be maxima owners in your area or close enough. ย I own 2 myself a 82 with a L28ET swap, 5 speed and a 84 5 speed on S13 Megan coilovers and S13 front suspension and welded diff. Quote Link to comment
ZeroTwo510 Posted April 20, 2019 Author Report Share Posted April 20, 2019 On 4/14/2019 at 11:48 PM, ArchetypeDatsun said: Nice to see another maxima owner should be maxima owners in your area or close enough. ย I own 2 myself a 82 with a L28ET swap, 5 speed and a 84 5 speed on S13 Megan coilovers and S13 front suspension and welded diff. ย Nice! Yeah i saw a bit of your build write ups they're pretty dang cool! ๐ I rarely see these if at all so I wanna enjoy it as much as possible. Mines rusted good but I don't mind since I got it cheap,I want this to be a thrasher or maybe a weekend drift machine. I'll come to you if I have any questions about my build,I'll definitely need all the help I can get ๐ Quote Link to comment
ZeroTwo510 Posted April 20, 2019 Author Report Share Posted April 20, 2019 How bad would it be if I use a 6303 bearing instead of a 6303n bearing for the main shaft on my fs5w71b transmission? I ordered this bearing through metro Nissan and I thought the PN was correct. Main difference is the one I bought doesn't have the snap ring retainer groove. What sucks is the dealer has a final sale policy so I can't return it. Any input would help a lot. ย Quote Link to comment
ZeroTwo510 Posted April 20, 2019 Author Report Share Posted April 20, 2019 Also is there any difference between the fs5w71b and fs5w71c transmission front covers? Are they interchangeable? The one on mine got damaged to the point where you can see daylight through it. I can easily find aย fs5w71c front cover at my local junkyard but I can't say the same for the fs5w71b cover. ย Quote Link to comment
Lockleaf Posted April 22, 2019 Report Share Posted April 22, 2019 B and C do not interchange if i recall.ย I was trying to answer that same question a couple month's ago.ย I looked up the cover plates and they have different bolt patterns, iirc. Quote Link to comment
Crashtd420 Posted April 22, 2019 Report Share Posted April 22, 2019 On 4/20/2019 at 4:21 PM, ZeroTwo510 said: How bad would it be if I use a 6303 bearing instead of a 6303n bearing for the main shaft on my fs5w71b transmission? I ordered this bearing through metro Nissan and I thought the PN was correct. Main difference is the one I bought doesn't have the snap ring retainer groove. What sucks is the dealer has a final sale policy so I can't return it. Any input would help a lot. ย I dont remember why the snap ring is there, but I would think you want it.... All the 6303 bearings are basically the same dimensionally, the letters after refer to other features... like being open, sealed or having the snap ring... 6303nr actually has the snap ring.... I'm not sure what the factory part number is..... Quote Link to comment
datzenmike Posted April 23, 2019 Report Share Posted April 23, 2019 B and C covers are the same BUT.... all C covers are 62mm counter bearing sized. Almost all B are 56mm counter bearing. '85 and '86 B covers are 62mm and will work with the C but that's it. Quote Link to comment
nl320what Posted April 26, 2019 Report Share Posted April 26, 2019 Just as a thought, if you wanted to keep it diesel but have parts way moreย readily available, think of using the Mercedes 240D/300D 4/5speed manual trans/4spd Auto along with the 4cyl/5cyl diesel engine choices. Quote Link to comment
Lockleaf Posted April 28, 2019 Report Share Posted April 28, 2019 I spent a long while considering an om617 Mercedes turbo diesel swap for my 720.ย I think size wise it would be a good fit. 1 Quote Link to comment
ZeroTwo510 Posted May 2, 2019 Author Report Share Posted May 2, 2019 Update: ย So I ended up trading my LD28 engine and miscellaneous diesel items for a L28,4 speed trans,SU carb setup,front sump pan and dizzy,pretty much everything to convert to gas. Since it's registered as diesel it's smog exempt here in California and this car is a beater ,I want itย to be super stupid simple to fix and drive. It's pretty much a bolt in process too just need the time to do the swap.ย The most difficult task for me is modifying or buying a front sump pick up tube to work on the L28 engine and stock tube location. I was thinking of maybe cutting the original pick up tube and brazing a flexible copperย extension tube so it extends forward down into the sump but not sure how that would hold up long term. If anyone has done this type of mod any advice would be appreciated. Also the l28 head and block I traded for are N42 matching,any benefits or trade offs with this set up?ย 1 Quote Link to comment
datzenmike Posted May 2, 2019 Report Share Posted May 2, 2019 Welded steel tube with a support brace to one of the main caps, NOT brazed copper. ย Something like this... Quote Link to comment
ZeroTwo510 Posted May 3, 2019 Author Report Share Posted May 3, 2019 On 5/2/2019 at 6:03 AM, datzenmike said: Welded steel tube woth a support bracee to one of the main caps, NOT brazed copper. ย Something like this... Found a local fabricator to extend and weld my old pick up tube,I'll post results once I get it back in my hands ๐ One thing I'm having trouble with is finding a replacement radiator at auto parts stores,most places can't order it anymore,is there a bolt in replacement that would fit off another car? I plan on going to the junkyard and finding one cheap but just need help narrowing down what cars to look for. 1 Quote Link to comment
ArchetypeDatsun Posted May 4, 2019 Report Share Posted May 4, 2019 Pretty sure you can use a Z car aftermarket aluminum radiator I know other have done it. ย If you got Facebook there is a 810 & 910 maxima page, pretty sure there is a couple guys in your area.ย ย The he cranks off the LD28 are worth quite a bit to the Z car guys inly thing is you would have had to get the crank inspected to make sure it was straight and cleaned up. ย Rebello buys the Diesel blocks for $300 he uses them as strokers as well for 3.5L. 1 Quote Link to comment
ZeroTwo510 Posted May 6, 2019 Author Report Share Posted May 6, 2019 On 5/3/2019 at 5:47 PM, ArchetypeDatsun said: Pretty sure you can use a Z car aftermarket aluminum radiator I know other have done it. ย If you got Facebook there is a 810 & 910 maxima page, pretty sure there is a couple guys in your area.ย ย The he cranks off the LD28 are worth quite a bit to the Z car guys inly thing is you would have had to get the crank inspected to make sure it was straight and cleaned up. ย Rebello buys the Diesel blocks for $300 he uses them as strokers as well for 3.5L. I've been lookimg at those and you're right it seems they would fit with minimal issue ๐ฎ i have my original one but I think it leaks,I think out of curiosity I'll ask a local radiator repair shop how much they charge to clean and seal my old one. I sent my gas tank off my 510 to these guys and they did a pretty good job cleaning it of rust and sealing it. I'll check it out definitely,I've run into a few already ๐ I really had planned to sell my LD28 and even posted it for sale on CL and Offer Up,i had a few serious responses but at the end of the day i need this car running fast and luckily i found a cool guy that had an engine for trade that'll bolt inย no problem. But easily I got an offers of around $850 for my LD28. Quote Link to comment
ZeroTwo510 Posted May 6, 2019 Author Report Share Posted May 6, 2019 Also update on my oil pick up tube for my front sump pan,i got it back from the welder extended and although it doesn't look the greatest it'll work. Modified my pan a bit too so there would be no interference with fitment. The pan is a diesel pan (has the feed in outlet on the side),not sure what car or equipment it came from but it'll clear my crossmember definitely. ย Quote Link to comment
ZeroTwo510 Posted May 11, 2019 Author Report Share Posted May 11, 2019 Does anyone on here have a non-power steering rack for these cars they don't want? I have power steering on mine but the pump from the ld28 won't work on the l28,I can do an even trade as well for my power steering set up?ย Quote Link to comment
