Dat521sun Posted October 24, 2019 Author Report Share Posted October 24, 2019 16 hours ago, banzai510(hainz) said: Cable linkage? if it feels like running out of gas always cycle the linkage and see if you see gas squiring in there. This will tell you if your acell pump is working or if there is gas in the float bowl. If no gas squirting then needle valve not letting gas in or fuell pump not working. make sure nothing stuck if Weber installed there was a thin carb adapters that can crack. Cable is slightly loose, pump is pumping gas. As soon as I get home I'll check if something is stuck and for cracks Quote Link to comment
Dat521sun Posted October 24, 2019 Author Report Share Posted October 24, 2019 (edited) 17 hours ago, banzai510(hainz) said: Cable linkage? if it feels like running out of gas always cycle the linkage and see if you see gas squiring in there. This will tell you if your acell pump is working or if there is gas in the float bowl. If no gas squirting then needle valve not letting gas in or fuell pump not working. make sure nothing stuck if Weber installed there was a thin carb adapters that can crack. Removed carb again, noticed that the gaskets between the carb and and plates are soaked in gas Edited October 24, 2019 by Dat521sun Adding picture Quote Link to comment
Dat521sun Posted October 24, 2019 Author Report Share Posted October 24, 2019 18 hours ago, banzai510(hainz) said: Cable linkage? if it feels like running out of gas always cycle the linkage and see if you see gas squiring in there. This will tell you if your acell pump is working or if there is gas in the float bowl. If no gas squirting then needle valve not letting gas in or fuell pump not working. make sure nothing stuck if Weber installed there was a thin carb adapters that can crack. Found the problem, the bolts on the second plates slowly dented the first plate, braking or cracking the seals/gasket in between causing leakage/vacuum problems. As a quick fix, I made some seal/gaskets and make sure bolts were not all the way down. Ordered adapter plates 1 Quote Link to comment
Dat521sun Posted October 24, 2019 Author Report Share Posted October 24, 2019 Thanks all of you who in one way or another helped me find the problems. Viva la Ratsun! 😉 Quote Link to comment
bilzbobaggins Posted October 25, 2019 Report Share Posted October 25, 2019 Red loctite. Stroffegen advised me to use it instead of the blue. I have never been able to keep one from vibrating loose. So far, so good on the red loctite. And I did have to take it back apart once already and was able to remove it. I used it on the studs for the top part of the adapter to keep them from moving down like I believe you are telling us they did. I used them on the allen bolts that do the rest. Hopefully this might help ya. Quote Link to comment
Dat521sun Posted October 25, 2019 Author Report Share Posted October 25, 2019 24 minutes ago, bilzbobaggins said: Red loctite. Stroffegen advised me to use it instead of the blue. I have never been able to keep one from vibrating loose. So far, so good on the red loctite. And I did have to take it back apart once already and was able to remove it. I used it on the studs for the top part of the adapter to keep them from moving down like I believe you are telling us they did. I used them on the allen bolts that do the rest. Hopefully this might help ya. Thanks, I'll be getting some red loctite tomorrow. I did a test drive and two came loose Quote Link to comment
banzai510(hainz) Posted October 25, 2019 Report Share Posted October 25, 2019 I have like the old style single pc tall adapter.fits fine w L16/18 with a tall air cleaner. If L20 one needs the short air cleaner so it don’t hit the hood as a L20 is taller. most times the cracked thin adapter it won’t idle. Quote Link to comment
Dat521sun Posted October 27, 2019 Author Report Share Posted October 27, 2019 The 521 is back on the road... Added another set of headlights, the center ones. This one have the option to connect to the turn signals and the halo blinks amber. I just connected it to stay on with my running lights. 3 Quote Link to comment
mainer311 Posted October 27, 2019 Report Share Posted October 27, 2019 Looks like a challenger. Quote Link to comment
banzai510(hainz) Posted October 28, 2019 Report Share Posted October 28, 2019 I like it Ratsun style!!!!!! Quote Link to comment
Dat521sun Posted October 28, 2019 Author Report Share Posted October 28, 2019 11 minutes ago, banzai510(hainz) said: I like it Ratsun style!!!!!! Thanks Banzai Quote Link to comment
Dat521sun Posted October 28, 2019 Author Report Share Posted October 28, 2019 15 hours ago, mainer311 said: Looks like a challenger. Watch out, hell cat inside 😉 1 Quote Link to comment
