Charlie69 Posted July 13, 2019 Report Share Posted July 13, 2019 (edited) On 6/24/2019 at 9:09 AM, Stoffregen Motorsports said: I don't know if I agree with you. That first carb looks suspiciously like a "smog legal" Weber that was available for Datsuns for a long time. I believe Redline sold the kit, and it used that same carb. You're right that the carb was used on many other applications. I think guys used to call it a Fiat Weber. I agree with Gene. The fuel pickup on the carb works for a J13 but is on the wrong side for the L motors. Edited July 13, 2019 by Charlie69 2 Quote Link to comment
Dat521sun Posted July 13, 2019 Author Report Share Posted July 13, 2019 Installed some Aftermarket Harley Davison LED Headlights, came out pretty good Maybe I'll connect the halo to the signal 😉 4 Quote Link to comment
d.p Posted July 13, 2019 Report Share Posted July 13, 2019 Looks good man. Were they plug and play? 1 Quote Link to comment
Dat521sun Posted July 14, 2019 Author Report Share Posted July 14, 2019 37 minutes ago, d.p said: Looks good man. Were they plug and play? Thanks D.P.... Yes, they are plug and play, comes with the 3 prong and everything, so you have low and high beam in a single headlight. 2 Quote Link to comment
Dat521sun Posted July 14, 2019 Author Report Share Posted July 14, 2019 12 minutes ago, d.p said: Got a link?? https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F163765306532 2 Quote Link to comment
Dat521sun Posted July 18, 2019 Author Report Share Posted July 18, 2019 Playing with plasti dip and pearls... What you guys think 3 Quote Link to comment
mainer311 Posted July 18, 2019 Report Share Posted July 18, 2019 Interesting. I’ve never played around with plastidip other than the plain black. 1 1 Quote Link to comment
banzai510(hainz) Posted July 18, 2019 Report Share Posted July 18, 2019 Horrible Most love the orginal Datsun colors 1 Quote Link to comment
Charlie69 Posted July 18, 2019 Report Share Posted July 18, 2019 What happened to your truck? 1 Quote Link to comment
Dat521sun Posted July 18, 2019 Author Report Share Posted July 18, 2019 (edited) 1 hour ago, banzai510(hainz) said: Horrible Most love the orginal Datsun colors I know, I love the original color, that's why I used plasti dip, to protect the paint and I can peel it whenever 😉 just like wearing clothes, you can change them as many time without disturbing your beautiful skin. Edited July 18, 2019 by Dat521sun 2 Quote Link to comment
Dat521sun Posted July 18, 2019 Author Report Share Posted July 18, 2019 53 minutes ago, Charlie69 said: What happened to your truck? It went to space and back 😂 2 Quote Link to comment
gene knight Posted July 18, 2019 Report Share Posted July 18, 2019 Dat521sun: pm sent Quote Link to comment
Dat521sun Posted July 18, 2019 Author Report Share Posted July 18, 2019 Under the Florida Rain 3 Quote Link to comment
BrothersGarage Posted July 18, 2019 Report Share Posted July 18, 2019 The goddamn rain drops are longer than your truck is tall. Screw that much of a downpour. Did you plastidip the reflectors on your tails or bluedot / smoke them? 1 Quote Link to comment
Dat521sun Posted July 18, 2019 Author Report Share Posted July 18, 2019 30 minutes ago, BrothersGarage said: The goddamn rain drops are longer than your truck is tall. Screw that much of a downpour. Did you plastidip the reflectors on your tails or bluedot / smoke them? Just rained for 20 minutes, then it stopped. Yes, plastidipped the reflectors, forgot to peel that little rectangular area 😅 2 Quote Link to comment
d.p Posted July 18, 2019 Report Share Posted July 18, 2019 Your truck confuses me. I don’t want to like it but I do. 1 2 Quote Link to comment
Charlie69 Posted July 19, 2019 Report Share Posted July 19, 2019 4 hours ago, Dat521sun said: Under the Florida Rain Get that 521 out of the rain!!! It will shrink! LOL 1 1 Quote Link to comment
BrothersGarage Posted July 19, 2019 Report Share Posted July 19, 2019 18 hours ago, Dat521sun said: Just rained for 20 minutes, then it stopped. Yes, plastidipped the reflectors, forgot to peel that little rectangular area 😅 Leave that shit! Quote Link to comment
Dat521sun Posted October 23, 2019 Author Report Share Posted October 23, 2019 (edited) Maybe you guys can help me... Truck was running perfectly, but yesterday, coming home it started to act weird. Truck was dying if I wasn't pressing the gas pedal. Finally I arrived home and died. It seems like a gas problem, so I checked and replaced filters, removed carb and make sure all bolts were tight and installed (no leaks) and now, truck idle way too high, like is going to keep accelerating. Any help would be much appreciated Edited October 23, 2019 by Dat521sun 1 Quote Link to comment
datzenmike Posted October 24, 2019 Report Share Posted October 24, 2019 When warmed up look and see if the choke is open. 2 Quote Link to comment
banzai510(hainz) Posted October 24, 2019 Report Share Posted October 24, 2019 (edited) Cable linkage? if it feels like running out of gas always cycle the linkage and see if you see gas squiring in there. This will tell you if your acell pump is working or if there is gas in the float bowl. If no gas squirting then needle valve not letting gas in or fuell pump not working. make sure nothing stuck if Weber installed there was a thin carb adapters that can crack. Edited October 24, 2019 by banzai510(hainz) 1 Quote Link to comment
BrothersGarage Posted October 24, 2019 Report Share Posted October 24, 2019 I had similar probs, bad vacuum leak caused it / car being stuck @ like 20% open Quote Link to comment
Dat521sun Posted October 24, 2019 Author Report Share Posted October 24, 2019 17 hours ago, datzenmike said: When warmed up look and see if the choke is open. Everytime I start the truck, goes over 4000 RPM, so I turn it off, but the choke is slightly close until it starts, the is wide open Quote Link to comment
