JDM Noob Posted April 10, 2019 Author Report Share Posted April 10, 2019 28 minutes ago, ]2eDeYe said: You can reuse the truck shaft to make the one piece. I didn’t know that, is there info here on Ratsun about that? 1 Quote Link to comment
]2eDeYe Posted April 10, 2019 Report Share Posted April 10, 2019 Well, by you, I meant the royal you. A driveshaft place should be able to build a new shaft from the components of your current shaft as the spline at the trans is the same. 1 Quote Link to comment
JDM Noob Posted April 10, 2019 Author Report Share Posted April 10, 2019 52 minutes ago, ]2eDeYe said: Well, by you, I meant the royal you. A driveshaft place should be able to build a new shaft from the components of your current shaft as the spline at the trans is the same. Understood, I did some searching on the forum and came to that conclusion but it seems like a better, more affordable solution. Can-of-worms question here, but if I wanted to make an all-aftermarket dash (tach, speedo, etc) would I still need the Can-Am adaptor for wiring up the truck or could I theoretically buy aftermarket gauges made for the vehicle that the engine comes from and use a (somewhat) unmodified wiring harness without much issue? Just thinking through all options. 1 Quote Link to comment
]2eDeYe Posted April 10, 2019 Report Share Posted April 10, 2019 You could do that with or without the canam box. It is for wiring the motor in to the chassis as a standalone system. 1 Quote Link to comment
JDM Noob Posted April 10, 2019 Author Report Share Posted April 10, 2019 50 minutes ago, ]2eDeYe said: You could do that with or without the canam box. It is for wiring the motor in to the chassis as a standalone system. Oh I see, that makes a bit more sense. 1 Quote Link to comment
JDM Noob Posted April 12, 2019 Author Report Share Posted April 12, 2019 Has anyone ever tried a Pull Loop style door handle in a 620 instead of the normal door handle? *thinking* To clarify I'm talking about the part that actually opens the door, I have seen the door handle itself replaced, but I was wondering if anyone had found success with that mod? Something like: Thoughts? Quote Link to comment
JDM Noob Posted April 12, 2019 Author Report Share Posted April 12, 2019 12 minutes ago, JDM Noob said: Has anyone ever tried a Pull Loop style door handle in a 620 instead of the normal door handle? *thinking* To clarify I'm talking about the part that actually opens the door, I have seen the door handle itself replaced, but I was wondering if anyone had found success with that mod? Something like: Thoughts? Seems redundant but I am responding to myself to let you guys know i am going to order these (https://www.ebay.com/itm/Door-pulls-Race-Rally-Motorsport-Drift-Car-handle-grab-straps-pair-GREY/222202543795) and I will update you on their functionality. Quote Link to comment
datzenmike Posted April 12, 2019 Report Share Posted April 12, 2019 Would take some getting used to. You have to pull the loop but push the door open at the same time? Seems to be different just for the sake of being different. In an emergency, a passenger not familiar with it would be fumbling around for a latch handle. Quote Link to comment
JDM Noob Posted April 12, 2019 Author Report Share Posted April 12, 2019 8 hours ago, datzenmike said: Would take some getting used to. You have to pull the loop but push the door open at the same time? Seems to be different just for the sake of being different. In an emergency, a passenger not familiar with it would be fumbling around for a latch handle. Fair points. They were only $26 for the pair shipped so I will see how they look and operate. 1 Quote Link to comment
