620slodat Posted January 31, 2021 Report Share Posted January 31, 2021 I do not have an IG account, and I was able to access this video. I'm assuming this was only a very short video. Don Quote Link to comment
mklotz70 Posted January 31, 2021 Report Share Posted January 31, 2021 Cool. There should have been four vids, each less than a minute. There should be an arrow on the right side/middle of the pic so advance to the next page. Thanks!! Quote Link to comment
620slodat Posted February 1, 2021 Report Share Posted February 1, 2021 Thanks for the heads up. I did find all four of the videos. Just to let you know, I definitely enjoy your videos and the tech involved in them, all of them. Don 1 Quote Link to comment
mklotz70 Posted February 1, 2021 Report Share Posted February 1, 2021 Ah....cool. Maybe I'll see about putting links here, as well. I'll try to go back and create a list of the links to catch up everything at once so that we don't end up with 20 or more separate posts on this thread. It would be nice if they would post with a thumbnail, but I don't know how to do that. Thanks Don. I'm happy to hear that. :) Quote Link to comment
mklotz70 Posted February 1, 2021 Report Share Posted February 1, 2021 (edited) This is everything that has been posted to IG already. I'll try to keep updating this as I go. Although, there is some consideration being given to completely getting off of social media...at least FB and IG. Couple of notes. If you see dots at the bottom of the pic/video, that means there's more than one page. If so, there should be an arrow on the right side in the middle. Clicking the arrow moves you to the next pic/vid. Some have just one, others can have up to 10. For sound, there should be a black button at the bottom right with a speaker icon. It should be slashed out to start with, then when you click on it, the slash goes away and you'll get sound. I hope this works ok. I really don't have the time to mess with this much. Cutting LCAs, starting https://www.instagram.com/p/CI6KNG8Jr-u/?utm_source=ig_web_button_share_sheet Still cutting LCAs, measuring https://www.instagram.com/p/CI_epRBJWKq/?utm_source=ig_web_copy_link Bandsaw cutting LCA https://www.instagram.com/p/CJCnwU3Jff_/?utm_source=ig_web_copy_link Marking sway bar hole https://www.instagram.com/p/CJHRpz8JCbX/?utm_source=ig_web_copy_link Machining sway bar hole https://www.instagram.com/p/CJHSVhZJ7JM/?utm_source=ig_web_copy_link Removing bottom plate with cnc mill and old cutter/endmill https://www.instagram.com/p/CJMbtH2pLP4/?utm_source=ig_web_copy_link Bottom plate, but with new cutter https://www.instagram.com/p/CJWYPRcpgqg/?utm_source=ig_web_copy_link Dealing with differences between parts from rockauto https://www.instagram.com/p/CJhCvZNJhkq/?utm_source=ig_web_copy_link 3D print for UCA Xshaft test https://www.instagram.com/p/CJwNAgApLLm/?utm_source=ig_web_copy_link LCA bore for cup https://www.instagram.com/p/CJwYnrppjuE/?utm_source=ig_web_copy_link 3d print finished, removing from bed https://www.instagram.com/p/CJxVhyCpac-/?utm_source=ig_web_copy_link 3D print close up of hole and threading https://www.instagram.com/p/CJzQ0l8Jvde/?utm_source=ig_web_copy_link 3D print on frame https://www.instagram.com/p/CJzRNa9pK5w/?utm_source=ig_web_copy_link More about LCA bore for cup https://www.instagram.com/p/CJzfwKqJ8XQ/?utm_source=ig_web_copy_link Even more about LCA bore https://www.instagram.com/p/CJ1iqd7p0b-/?utm_source=ig_web_copy_link 3D print for lathe chuck depth stop to make the LCA cups https://www.instagram.com/p/CJ3z0FGJp_A/?utm_source=ig_web_copy_link Prepping stock for the cups https://www.instagram.com/p/CKE70-hJWp7/?utm_source=ig_web_copy_link Depth stop on lathe https://www.instagram.com/p/CKFNdFnp9Kg/?utm_source=ig_web_copy_link Cutting side one of the cups on the lathe https://www.instagram.com/p/CKFPxiFpRR-/?utm_source=ig_web_copy_link Start of mill work on cups.....oops https://www.instagram.com/p/CKHqPnuJiPY/?utm_source=ig_web_copy_link Cups being milled out https://www.instagram.com/p/CKKM3E1poTN/?utm_source=ig_web_copy_link Gusset prep for underside of LCAs https://www.instagram.com/p/CKPSnJjJBQg/?utm_source=ig_web_copy_link Over an hour of welding and barely half done on a set of arms (pic) https://www.instagram.com/p/CKZuQ0FJ8TK/?utm_source=ig_web_copy_link Laser cut parts for the LCAs https://www.instagram.com/p/CKown86pk7h/?utm_source=ig_web_copy_link Welding setup info https://www.instagram.com/p/CKrbI_-JKsK/?utm_source=ig_web_copy_link Couple of weld pics....nothing to write home about. https://www.instagram.com/p/CKrrDSzpA2U/?utm_source=ig_web_copy_link Look at coil over and shock https://www.instagram.com/p/CK9oox4pQsl/?utm_source=ig_web_copy_link Upper shock reinforcement https://www.instagram.com/p/CLIN7N2p3gd/?utm_source=ig_web_copy_link Current to 2/10/21 Edited March 20, 2021 by mklotz70 2 Quote Link to comment
