zacc Posted March 26, 2019 Report Share Posted March 26, 2019 just curious, does anyone have a preferred brand of coil overs they run on their 210? mine is streetable to an extent, but i’m pretty sure my shocks are blown out so the ride is rougher than fuck. thinking about going with weld ons... any suggestions? Quote Link to comment
datzenmike Posted March 27, 2019 Report Share Posted March 27, 2019 Replacing the coil springs won't fix worn shocks. How would it? If your struts are original they will have oil bath dampers that can be drained and the thin oil replaced with motorcycle fork oil that is thicker. I'm running 20w in mine. Thicker viscosity requires more energy to push through the valves so the damping is much improved. Cost? About $15 US for a liter which is enough for three struts. If they have already been replaced with inserts there's no getting around paying $120+ each to replace with something substantial. Always replace all four corners. You'll need a good pair of gas charged shock absorbers on the back. Quote Link to comment
afracer Posted March 9, 2020 Report Share Posted March 9, 2020 Gecko racing coilovers on eBay will fix you up. Quote Link to comment
