matrophy Posted March 25, 2019 Report Share Posted March 25, 2019 Working on soundproofing my 1986 base standard cab 720 pickup. I found that my shifter boot had come apart and it also has a rip in it so since most road noise is coming from the floor area, I want to replace the boot while I have the carpet removed. I don't have a console so many of the available thinner boots won't work in my situation. I wouldn't mind having a console so I'm wondering if that is easy to install or will I have a conflict with the heater bits, etc? Which console will work? I saw previous posts where someone was able to post the several models of car/truck that use this same shift boot but the links in the post were dead. I would love to have that info because searches for my specific truck don't turn up any choices. Here are photos of my shift boot. The very bottom piece had come off and it looks like it was put together originally with contact cement so if push comes to shove, I could probably reattach it the same way but I'd rather replace it while I have the interior apart. 1 Quote Link to comment
Spiff Posted March 31, 2019 Report Share Posted March 31, 2019 I got new ones from Nissan. Try that, I used nissan4u.com to find the part number which I sent to the dealer. As for consoles there are two types (differ in length) because the 720 had a short tail and a long tail transmission, get the console with the metal bracket and it should bolt up. Might need to drill two holes in the floor for the rear mounting. I had too 1 Quote Link to comment
matrophy Posted April 1, 2019 Author Report Share Posted April 1, 2019 I was able to crazy glue it back together (whch worked surprisingly well) and will keep an eye out for a console. The nissan4u site couldn't find my VIN so I need to double-check that I wrote it down correctly. Thanks. 1 Quote Link to comment
Lockleaf Posted April 1, 2019 Report Share Posted April 1, 2019 Is there something wrong with a factory 720 console? Easiest is to install one of those. 1 Quote Link to comment
matrophy Posted April 1, 2019 Author Report Share Posted April 1, 2019 No, I just wasn't sure if it would fit 1 Quote Link to comment
Lockleaf Posted April 1, 2019 Report Share Posted April 1, 2019 Yes it will fit. All you need to figure out is long or short transmission, then buy the console to match. For it to be bolt in, you will also need the mounting bracket. Stock console also allows addition of stock volt meter and oil pressure gauge. 95% of the wiring for those is already in the vehicle. Need 18 inches of one wire, the correct pressure sending unit, and a resistor for the voltmeter. 1 Quote Link to comment
matrophy Posted April 1, 2019 Author Report Share Posted April 1, 2019 I’m guessing that what transmission I have is a function of where the shifter is located on the tunnel and therefore the console I need will have the shifter in the same place or is there some other way to find that out? 1 Quote Link to comment
Charlie69 Posted April 1, 2019 Report Share Posted April 1, 2019 The console length difference is 2 wheel and 4 wheel drive. Quote Link to comment
Lockleaf Posted April 1, 2019 Report Share Posted April 1, 2019 While Charlie is mostly right, there are freaks out there. And yes, the shifter moves about 4-5 inches between the two versions 1 Quote Link to comment
MaxChlan Posted April 2, 2019 Report Share Posted April 2, 2019 (edited) From what I have seen, single cab 2WD trucks with a bench got the shorty, 2WD King Cab trucks got the long one, and all 4x4s got the shorty. There may be 2wd single cab trucks that got a long one because they were STs or deluxes with bucket seats, in which case they would have had the center console already in them. I could be wrong on that exact fact pattern but that's just been what I've seen. My guess is that you have a shorty. Post a picture of the interior and we'd be able to tell you 😂 Edited April 2, 2019 by MaxChlan 3 Quote Link to comment
Charlie69 Posted April 2, 2019 Report Share Posted April 2, 2019 (edited) Never seen a shorty in a 2 wheel drive. The 2wd bench seat standard cab trucks I have had the long front but also had a notch in the bench seat for the shifter. These were all 1980 trucks. Edited April 6, 2019 by Charlie69 Quote Link to comment
matrophy Posted April 2, 2019 Author Report Share Posted April 2, 2019 Thanks guys. Here's a photo 1 Quote Link to comment
wayno Posted April 2, 2019 Report Share Posted April 2, 2019 (edited) All 1985/86 Nissan 720 2wd reg cab short box trucks had a short 5spd, all kingcab 2wd trucks all had long shafts, short transmission short console, long transmission long console. There are also a few strange short consoles that have the visor built into them instead of the gauge brackets holding them on, I found one in a 4wd I believe, not sure who made them. I might take a couple consoles to the Portland swap meet to sell. Edited April 2, 2019 by wayno 1 Quote Link to comment
CicliDevotion Posted April 5, 2019 Report Share Posted April 5, 2019 @wayno do you have any short consoles with gauges in brown? 1 Quote Link to comment
wayno Posted April 5, 2019 Report Share Posted April 5, 2019 I do not have any consoles in tan/brown or blue. 1 Quote Link to comment
matrophy Posted April 5, 2019 Author Report Share Posted April 5, 2019 48 minutes ago, CicliDevotion said: @wayno do you have any short consoles with gauges in brown? Or in blue? 1 Quote Link to comment
Madkaw Posted March 26, 2020 Report Share Posted March 26, 2020 So I got one of these rubber boots as in the first post . I ASSumed it fit into console on these trucks , but didn’t know . Now I have it in my hands I don’t see how it would attach to the console , so maybe never meant to ? I’d rather have it then the leather boot . I guess I could make something that would work, but want to make sure there isn’t clips that work for this . 1 Quote Link to comment
matrophy Posted March 29, 2020 Author Report Share Posted March 29, 2020 If it looks like the boot in the pictures, it fits into a hole in the tunnel 1 Quote Link to comment
