Nustad 510 Posted March 12, 2019 Report Share Posted March 12, 2019 Hi everyone, Does anyone have photos of their rear control arms after trimming the leading edge for wheel clearance? Thanks, Shaun. Quote Link to comment
paradime Posted March 12, 2019 Report Share Posted March 12, 2019 Sorry Mate, I don't have photos but I can describe what I did to avoid using rear spacers. When I bought Enkei wheels for my 510, I knew the offset would be right on the edge of needing a spacer. I bolted the rim on the hub before I mounted the tires and as feared they bound on the trailing arm. I could see it was close so instead of using a spacer, I marked by scratching the paint exactly where the inner edge of the rim made contact with the leading lip of the arm. I removed the wheel and used a cutoff wheel to grind just a bit of the lip off. I installed the wheel again and repeated the process until the it had about an 1/8" 3mm space between the rim and lip (for wheel flex). All together I took about a 14mm wide X 10mm deep notch out of the lip. I've seen people take much more than that, where it actually cuts into the razed part of the arm a bit, but they welded a filler plate of steel to to cover the hole and maintain the integrity. Hope this helps. 1 Quote Link to comment
Nustad 510 Posted March 12, 2019 Author Report Share Posted March 12, 2019 Thanks Paradime, Im running 14 x 6.5 +25 wheels on the rear. BR Specials. A Watanabe look a like. What you described is what I was thinking of doing. In my case, a bees d**k is all I need to shave off the edge of the trailing arm to achieve the correct clearance. One poorly positioned wheel weight is the only thing preventing the rim from turning freely. I did specifically ask the wheel shop to put ALL weights inboard. 1 Quote Link to comment
banzai510(hainz) Posted March 17, 2019 Report Share Posted March 17, 2019 (edited) I run 15x7 +25 AND HAVE NO PROPLEM..REARS I have 195/45 tire but 195/50 should be fine also. IN front is close with stuck 510 struts. Edited March 17, 2019 by banzai510(hainz) Quote Link to comment
paradime Posted March 17, 2019 Report Share Posted March 17, 2019 On 3/12/2019 at 7:38 AM, Nustad 510 said: Thanks Paradime, Im running 14 x 6.5 +25 wheels on the rear. BR Specials. A Watanabe look a like. What you described is what I was thinking of doing. In my case, a bees d**k is all I need to shave off the edge of the trailing arm to achieve the correct clearance. One poorly positioned wheel weight is the only thing preventing the rim from turning freely. I did specifically ask the wheel shop to put ALL weights inboard. I have the same dimension rims as Bonzai, but had rubbing because not all rims are designed alike. Yeah, not surprising you had issues on a 14" rim with +25mm offset. Rubbing is usually worse the smaller the rim, but yours are 6.5" wide so that narrows the inner edge by 6.35mm. I have 205/40s on the rear, but by the time the arm extends past the inner lip of the rime, it angles out enough so on a 7" rim there's plenty of room for an 8" wide tire. In my case I have a good 5/8" (15.875mm) space between the arm and wall of the tire. I had to roll the lip, pound out the inner shoulder, and perform a bit of crowbar flaring of the fender to get them in there, but I got it all tucked under the car nice and neat. Good luck on yours, and send photos! Quote Link to comment
