85-86 720 diff ratios for auto and manual trans
jagman
  • Replies 21
All automatics were 3.70 on the 2wd '85 720 truck. None of the other 4 had that ratio... although one of those 4 never came with an automatic, so really there were 3 other ratios.
Find the engine tag riveted to the passenger side inner fender just below the hood hinge.
this is for a 5 speed....
Bottom line...
TRANS / AXLE............... FS5W71B................ HF38  or HF43 or HF 35
38 is 3.889 ratio
An automatic tag would say...
TRANS / AXLE...............3N71B.................... HF37
37 WOULD BE 3.70 RATIO
Bottom line...
38 is 3.889 ratio
Mines an 85 auto and I got the 3.889 gears
The tag says 3N71B and HF38???
Well ultimately Nissan may have changed the published specs, ya never know. But 3.70 is what it's supposed to be. The other thing is that in 35 years maybe the differential was swapped.
Any chance the speedometer is reading 5% high? That's only 2.5 MPH @ 50 MPH and may not be noticeable.
Mines a L3N71B HF38. Nope stock  rearend. Grandpa brought  the truck from the dealership  with just 4 miles on it.
Edited by 85"720
50 minutes ago, datzenmike said:
Well I'll try to keep track of that info.
L 3N71B? L may be for locking torque converter. There were also E3N71Bs in the 280zx but not the 720. The E was a heavier duty transmission.
Yea mine has a locking  torque converter. I can feel it lock up  at 40-45 mph.
I believe  the e stands for electronic if I'm not mistaking. Kinda like  GM's 4l60e. 4=the amount  of  gears. L= longitude. 60 =the strength of the trans. E = electronic.
Nissan uses the E on engine codes to signify multi port EFI. D for dual OHC, i for throttle body injection, R for supercharged and so on. The 3N71B has no electronics. Well reverse light switch and ignition interlock.
Mike I also ran across an 85 720 regular cab short bed that had a HF 35, 5 speed & Z24.  I know the tag was correct as we pulled that set of gears for Shawn's 521 convertible.  He has a Z24 5 speed out of a 84 720.
Needed a colorful picture in this thread!  LOL
Well DatzenMike, I looked all over the firewall, inside the door panels, inside the dash, under and in the fenders and I can't find a plate like you show in the picture.  When I have a chance I will look at the long bed and see if it has the plate affixed.  Thanks for the info on what should be there and if the long bed has a lower ratio than 3.70 (like 4.11 can I swap rears?  Will I have to change the speedometer cable as well?
Charlie yes for the standard transmissions there was a 3.545 gear for the Z24 5 speed pick up. There was a 3.364 on the Mileage Option Z20S which only came with 5 speeds. There was a 4.375 on the 5 speed Cab/Chassis only with a 5 speed and 3.889 on the diesel trucks that were also 5 speeds.
The question was what was used on the '85-'86 Z24 automatics and I say 3.70. My info shows only the 3.70 was used. But as suggested maybe the 3.889 was also used.
Well,  I have looked and it must have been forgotten during the build cause there aren't any holes there either.  Can you make a lightweight samurai sword from aluminium?
Charlie, I think this truck is about the same age as my long bed which is 85-86.  I don't know what the run of years is for the 720 but based on the build number they have to be close.
I don't know how many 720's sell per year  but the build numbers are 372089 for the long bed and 308468 for the junker.  That's 63,621 units earlier than the long bed.  Would that make it an 81-82 assuming they sold ~ 20,000 per year?
There were reg cab short wheelbase, reg cab long wheelbase and KC
For 1980 there were 168,999 reg cab short wheelbase trucks made and the same number of King Cabs... then there were the Long beds and the Cab Chassis models and to further confuse there were two plants operating with even more on top of these. That's a lot of trucks.
What truck do you have?
