Said Torres Posted February 24, 2019 Report Share Posted February 24, 2019 Hi guys this will be my first post here , so ive ran into some problems on setting up my msd (6al2) my engine is the originally z24i, i have the 720 distributor , yes it’s timed & i’ve used the 720 shaft , i was wondering if anyone has information on how to wire up the vacuum advance dizzy to the msd ? Quote Link to comment
datzenmike Posted February 24, 2019 Report Share Posted February 24, 2019 To use a 720 distributor you would need a carburetor with a ported vacuum advance source on it. The Z24i had the timing computed by the EFi with input from the crank angle sensor (CAS) What's wrong with the stock distributor's ignition???? You won't get a better ignition than that. Quote Link to comment
