oukippy Posted February 21, 2019 Report Share Posted February 21, 2019 Hello, I'm trying to understand how should the headlights work and to know if mines have a real problem. I understand that the light switch have 3 positions : off, low and high. Here's a little drawing of what happens when I use the switch (obviously on off there is no light at all) : I think it's not normal that the 4 headlights are only enlighten when I put the switch in high position. My guess is : - on low position, H1 and H4 should be enlighten at the low level of brightness ; - on high position, H1 and H4 should be enlighten at the low level of brightness and H2 and H3 should be at high level. Is it correct and what could cause the problem (if there is a problem) ? It's hard for me to understand because I've never seen a 620 before buying one ? Quote Link to comment
sebpv Posted February 22, 2019 Report Share Posted February 22, 2019 read up on here http://datsun1200.com/modules/mediawiki/index.php?title=620_Headlight_Wiring Quote Link to comment
sebpv Posted February 22, 2019 Report Share Posted February 22, 2019 (edited) From the diagram, on LOW: h2 and h3 are ON. When on HIGH: all lights are ON. Edited February 22, 2019 by sebpv Quote Link to comment
datzenmike Posted February 22, 2019 Report Share Posted February 22, 2019 When you pull the headlight switch out to the first position only the parking lamps (two front amber an the red tail lights PLUS the front side amber marker or clearance light and the rear red clearance lights, the license plate lamps and the dash lights. Like your first picture. No headlights should be on. On the second position, pulled out all the way, all the above applies, plus power is sent to all four headlamps. The headlamp switch can only select hi or low beams there is no third option so depends what the hi/low switch is set at. The hi/low switch is on the turn signal stalk and you move it towards or away from the dash for hi or low beams. If all you have is all four lamps lit, maybe you are on hi beams. The outer two lamps have a low beam and a hi beam filament inside. The inner middle two lamps have just a hi beam filament. If you select low beams only the outside two lamps light. When you switch to hi beams the low beam turns off and all four hi beam filaments light. 1 Quote Link to comment
sebpv Posted February 23, 2019 Report Share Posted February 23, 2019 oups. I thought i read it right on the first webpage. Been a while since I had headlights on my truck ? Quote Link to comment
oukippy Posted February 23, 2019 Author Report Share Posted February 23, 2019 (edited) Thak you very much for the explanations . My problem could be related to the hi/low switch. Nothing changes when I move it towards or away. I made a little video to show you how the stalk is loosen. I suppose it's not normal and could explain that I can't switch the beams : Any idea of what could happen ? I forgot to say that I have no problem with the turn signal switch. Edited February 23, 2019 by oukippy Quote Link to comment
datzenmike Posted February 23, 2019 Report Share Posted February 23, 2019 Looks like the switch is moving when the lever is moved. I would expect the switch to be solid. Split the plastic 'clam shell' off the steering column and have a better look. IIRC there is a Phillips screw that tightens the turn signal / hi low switch assembly to the steering column tube. 1 Quote Link to comment
oukippy Posted February 23, 2019 Author Report Share Posted February 23, 2019 could it be the same problem as this 521? Quote Link to comment
datzenmike Posted February 23, 2019 Report Share Posted February 23, 2019 I bet it's very similar. There were 3 different turn signal switches used during the 620 run with different plugs and number of wires. Up to December '72. Jan '73 through July '77 and Aug '77 ('78 model year) and on build dates Quote Link to comment
oukippy Posted February 23, 2019 Author Report Share Posted February 23, 2019 I unmount the lever to under how it works. I've found the problem. It was poorly repaired I think. There's no contact within the switch when I pull the lever. After removing everything, I used a screwdriver instead of the little piece of metal and was able to change the beams as expected. I'll send pictures later to ask for your thinking on how to repair. It's not a very expensive part but it's damn more fun to repair then to buy in Thailand ! lol Quote Link to comment
oukippy Posted February 23, 2019 Author Report Share Posted February 23, 2019 The lever was hold by a simple screw : I think there is something missing here : The missing part should push this little piece of metal which make the contact between wires : According to what I saw on the 521 post, there should be a ball bearing and a spring. I found a ball bearing under the carpet and was clever enough to keep it but I'm not sure it's the good one. Beside, I don't have the spring. Any idea on how to fix it ? Quote Link to comment
datzenmike Posted February 23, 2019 Report Share Posted February 23, 2019 Looks like a roll pin should be in there. The ball and spring help it seat into one of the three positions and not flop around. Quote Link to comment
oukippy Posted February 23, 2019 Author Report Share Posted February 23, 2019 I think I'll have to find a spin and ball bearing. I hope I won't need to buy a new turn signal switch just for 3 grammes of metal... Quote Link to comment
Draker Posted February 24, 2019 Report Share Posted February 24, 2019 I bought a repop switch and used parts from it to rebuild a stock switch before. Turned out the repop was not a direct fit, but had the parts to fix mine. Quote Link to comment
oukippy Posted February 25, 2019 Author Report Share Posted February 25, 2019 On 2/23/2019 at 10:16 PM, datzenmike said: Looks like a roll pin should be in there. The ball and spring help it seat into one of the three positions and not flop around. Do you think the spring is supposed to enter in the lever's hole ? I'm trying to find a replacement spring and ball bearing. If it should fit in the hole, I can measure it and determine the diameter of the spring (and ball) which will be a good starting point for replacement finding. Quote Link to comment
oukippy Posted February 25, 2019 Author Report Share Posted February 25, 2019 I've found the spring ! it was in the lever's hole... I write here the measured dimensions if anyone have lost it : spring length = 6.72 mm = 0.2645 in spring diameter (outside) = 3.73 mm = 0.147 in hole length = 7.62 mm = 0.300 in hole diameter = 3.91 mm = 0.155 in Consequently I only need the good ball bearing. If I see correctly on the next picture, the ball should be in the lever hole so I suppose that the diameter is the same : Quote Link to comment
datzenmike Posted February 25, 2019 Report Share Posted February 25, 2019 Just to be absolutely clear.... it should be assembled as shown above. I would call the 'lever hole' the one that the poll pin fits into. I had my 710 turnn signal apart and it was a total bitch to get that spring compressed and get the roll pin in. The receiver for the ball is sort of shaped like this... VV with the ball being pushed down into the V and held there by the stiff spring so the arm does not flop about. Quote Link to comment
oukippy Posted February 25, 2019 Author Report Share Posted February 25, 2019 2 minutes ago, datzenmike said: Just to be absolutely clear.... it should be assembled as shown above. I would call the 'lever hole' the one that the poll pin fits into. I had my 710 turnn signal apart and it was a total bitch to get that spring compressed and get the roll pin in. The receiver for the ball is sort of shaped like this... VVV with the ball being pushed down into the V and held there by the stiff spring so the arm does not flop about. I think the screw fits well in the lever hole. My question is : does the ball enter in the other hole ? The one where you have the spring in. Quote Link to comment
datzenmike Posted February 25, 2019 Report Share Posted February 25, 2019 The screw might work... then again it may be why the ball fell out. Yes the spring first then the ball. The spring is pushing outward on the ball. 1 Quote Link to comment
oukippy Posted February 25, 2019 Author Report Share Posted February 25, 2019 For sure it's not the best option but I don't have the poll pin. Is this correct : Quote Link to comment
datzenmike Posted February 25, 2019 Report Share Posted February 25, 2019 I'm sure you can buy them. I don't know what the brass part is, looks right though. Quote Link to comment
oukippy Posted February 25, 2019 Author Report Share Posted February 25, 2019 (edited) I've found the brass part where the red arrow is pointing : I don't know if it should be there or in the "green arrow place". I don't know how to place it too... Edited February 25, 2019 by oukippy Quote Link to comment
oukippy Posted February 25, 2019 Author Report Share Posted February 25, 2019 it looks very similar to the one here : Quote Link to comment
datzenmike Posted February 25, 2019 Report Share Posted February 25, 2019 Could be it. Like I say I didn't get my 710 one that far apart. and it may be different but it did have the spring and ball. Quote Link to comment
oukippy Posted February 25, 2019 Author Report Share Posted February 25, 2019 1 minute ago, datzenmike said: Could be it. Like I say I didn't get my 710 one that far apart. and it may be different but it did have the spring and ball. Ok I was thinking you did. I'll try different configurations probably. Do you confirm that the ball was partly inside the spring hole and the spring fully inside ? Quote Link to comment
