tcphil3 Posted February 21, 2019 Report Share Posted February 21, 2019 I was driving down the street the other day with my dad and we came across this beautiful Nissan 720 with only about 70000 mi. I said screw it i had been looking for a hardbody or some other import pickup. Its a great truck and it runs pretty good. But the interior is pretty bad but its perfect for me. Im 17 and i live in CO, i blew my money bought the truck for 3000. I just think its a great vehicle and has a lot of history. I put new shocks in the truck and replaced little bushings and bullshit here and there. I just want to know what are the main things i should look out for? Is there any place in the z24 engine i should be checking for wear or anything else? Also, i have 2 different seats in the driver and passenger one with fabric and one thats vinyl i think, so were could i find interior parts and carpet? Is there a seat that bolts up without any mods? Also my starter turns the engine fine but occasionally it just wont turn over and ill have to cycle the ignition 5 or 6 times to get it to turn over. Thanks for any help! Just been feeling all lonely because no one where i live knows how to work on these things and ill be honest i dont really either but i want it to run good and look clean in the interior. Thanks again! 1 Quote Link to comment
wayno Posted February 21, 2019 Report Share Posted February 21, 2019 Re-torque the head bolts one at a time, it doesn't matter the order as long as all of them are done, I believe it is 60lbs. I am sure someone else will tell you this also, the Z24 is famous for blowing the headgaskets, Nissan's fix is the re-torque, I also believe it is done cold. 2 Quote Link to comment
datzenmike Posted February 21, 2019 Report Share Posted February 21, 2019 What wayno said, cold re-torque. Just be sure that only one bolt is loose at a time. This will keep the bolts tight against the gasket. The Z24 tends to blow the head gasket at 100K mile intervals. Do this once a year and avoid this. Intermittent start could be the ignition switch and it could be the starter but because it's cheaper and easy to check it could be the actual start signal from the ignition to the solenoid. That's the small Black/Red stripe wire (if manual) or Black.White wire. (if automatic) First make sure it's on there snug and simply not loose first. Otherwise pull off and check the voltage with a meter while turning the ignition to START. It should read battery or 12 volts. If it's 7-9 volts the solenoid isn't getting a strong enough signal. (caused by old wire and the long run from the battery all the way inside the cab to the switch and all the way back) What you can do is get a relay and use this weak signal to apply a stronger one from the battery. It's called a 'hot start relay' and is wired like this... On 2/19/2009 at 12:34 AM, nukeday said: I'm going to do this on my truck, and leave the 30A fuse out. It's not ready to start, but I want to test the rest of the electrics. ? You could run a jumper wire from the positive terminal and touch it to the starter solenoid terminal. Make sure you are out of gear. If it starts turning every time unlike the ignition switch then I would say it's not the starter or the solenoid but a weak start signal from the ignition. 2 Quote Link to comment
tcphil3 Posted February 22, 2019 Author Report Share Posted February 22, 2019 Thanks for the tips ill make sure to avoid that potential blown head gasket haha. Ill post again with any questions or things i run into. 1 Quote Link to comment
Lockleaf Posted February 22, 2019 Report Share Posted February 22, 2019 90s 300zx seats fit with little effort. I believe Isuzu trooper and dodge neon seats are also known to nearly bolt in. Don't get electric seats unless you want to relocate your ecu which is under the drivers seat. Most electric motors hang down too low and hit the ecu. 2 Quote Link to comment
Jon's AD3 720 Posted February 24, 2019 Report Share Posted February 24, 2019 I bought a replacement carpet for my 83 720 at Auto Custom Carpets Inc. I haven’t installed it yet because still have some work to do on my floor pan, but it appears to be custom fitted for the truck. Several colors are available. 2 Quote Link to comment
