89Sunny Posted February 19, 2019 Report Share Posted February 19, 2019 First I'm new here and new to this truck. I've read this great write up and have done my best to follow it. The only difference being I have drum brakes. This is the passenger side (Drivers side in US) the steering knuckle side is coming down slightly but this side does not seem to budge. I've used a bit of force. Any suggestions? Thanks Todd Quote Link to comment
datzenmike Posted February 20, 2019 Report Share Posted February 20, 2019 Take a picture farther back. I need some landmarks. Nice rims BTW. Quote Link to comment
89Sunny Posted February 20, 2019 Author Report Share Posted February 20, 2019 Here you go. The arrow is pointing to the bolt I posted in the first picture. This side is starting to come down but I would not think it would take this much pressure/work to get it loose. These have been off before as the guy before me had the whole truck sitting lopsided. Thanks about the rims. They are a massive 13" and will be for sale one I get an offset set of wheels (probably next year at this point). Quote Link to comment
datzenmike Posted February 20, 2019 Report Share Posted February 20, 2019 Place a hydraulic jack under the lower control arm and lift it up level, or more level. I think it's kinked and the strut bottom with the drum wants to extend straight down it's length or even outward but the lower control arm can only swing down in, in an arc. This might allow you to get the bolt out but HAVE A CARE! it will be under some spring tension when you lift up. Keep clear. When you lower it should just fall apart. I've had the same thing with struts but the bolts always came out, it was just hard to separate. I always have to pry down on the LCA and it pops out. Quote Link to comment
89Sunny Posted February 20, 2019 Author Report Share Posted February 20, 2019 Thanks I will give that a shot once/if the snow stops here today. Quote Link to comment
89Sunny Posted February 21, 2019 Author Report Share Posted February 21, 2019 Well the drivers side came off like it could not wait to do so. The passenger side is still stuck as it ever was. I followed the instructions posted above for the drivers side (use big pole) Quote Link to comment
89Sunny Posted February 26, 2019 Author Report Share Posted February 26, 2019 Well I got them off. The passenger side was not easy and it took two grown men an hour of beating it with a hammer, spraying it with PB Blaster and finally getting a screwdriver in enough to pry it apart. You can see the fine paint job the guy before me did. Who needs to tape? Quote Link to comment
Draker Posted February 27, 2019 Report Share Posted February 27, 2019 Nice work! Heat would have helped a bit I'm sure, but not every one has a torch in their tool box. I've had good luck with map gas. Quote Link to comment
89Sunny Posted April 14, 2019 Author Report Share Posted April 14, 2019 I got the struts/coilovers back and they look AWESOME. I will be working on putting them back together tonight and mounted this week. Quote Link to comment
Rat-a-tat-Dat Posted April 14, 2019 Report Share Posted April 14, 2019 Salutations! A good looking truck you got there. Front bumper could use some TLC, but over all has straight lines. Those coilers are shinny 😎 Quote Link to comment
