distributor datsun 620
  • Replies 4
What GD 510???
The original PL510 distributors were points style. For this to work in a '79 620 (which are EI and don't have points) you will need a points coil and a ballast resistor to go with it.
If this is from an A10 and built before June '78 you have a remote igniter EI and will need the ignition box mounted under the dash or easily convert using a General Motors HEI module. If built after June '78 and until June '80 and Non California emissions, you have a matchbox and will drop right in. From July on won't work.
