L16 Flex Plate
Swift510
  • Replies 5
Do you have an automatic 510 or are you looking to use the flexplate in a race car with something like a QuarterMaster clutch set up?  If an auto car.....what Mike said above!  If a race car, I think either flexplate will work, might have to figure out a mod with the starter..........
TJ
You used to be able to still buy the starter ring gear. It would be the same for any vehicle using the 71C transmission. The 510 ring was last used on the D21 and WD21 with the Z24i engine but KA flywheels will swap and work, so all KA24E and DE starter rings should work. The KA ring is also used on the VG30 so add them as well.
Now cut out a plate and weld it on yourself.
