L18 block build
I have an L18 block which I just found out it has a W which is rare?
I also have a W53 peanut head
bored .040 over
272 cam and smimed due to decking the head
I was wanting ideas on things I can add to make it cool or things that are nifty
i also have a 40mm side draft,
  • Replies 10
I have a birthmark on my ass that looks like a strawberry. I don't know if that's special or not.
The W53 is a Japanese head so it only gets here on an import engine. Perhaps the W L18 was the engine it came on. Is the dip stick in the usual place next to the starter? Have you noticed a second pinched off dip stick tube elsewhere? The L18s here, were only used on the '74 620 truck and the same year 710 and the '73 610. Does it have a truck rear sump oil pan or one for a car?
A closed chamber head on an L18 would give 9.15 compression but if the head was milled it will be above that.
Do you have a stock L18 exhaust on it?
 The dip stick is on the exaust side, and I would post pics but I don’t know how!
as far as I know this engine is 10-1 or 11-1
The L18s were made into the '80s I think but used elsewhere. This one will have the raised boss with 4 bolt holes around the oil filter?
10-1.... 11-1   compression? I don't know, not in stock form. 9.85 with flat tops. Higher with head milled.
It has the 4 bolt holes around the oil filter and yeah as far as I know this engine is running 10-1...11-1
its not stock it’s all done up!
